Infill Problem
December 01, 2013 01:49PM
Hello,
I've some problem printing the test cube 10x10, the perimeters is ok, but the infill is ugly.
My configuration is prusa i3 Hot end E3d (Metal) nozzle 0,5 + marlin + slic3r + pronterface and ABS.
i've tried all kind of configuration (extruder multiplier/ e step calibration etc) but without any result, the final dimension of the print are ok but the top layer is higher than print !!!
here is some detail (if it could help):
printing temp 220
fill density 0.4
extruder multiplier 1
layer height 0.5
enclosed you will find some test ( I've one billion of cube…)
many thanks for any help and sorry for my english… smiling smiley
Thanks
Alex
open | download - 20131201_193306.jpg (187.2 KB)
open | download - 20131201_193254.jpg (180.1 KB)
Re: Infill Problem
December 03, 2013 12:41AM
You should try increasing the Top solid layer in Slic3r---> PrintSettings --> Layers and Perimeters --> Horizontal Shells ---> Solid Layers --> Top
Also you can do this Print Settings --> Infill --> Top/bottom fill pattern --> CONCENTRIC
Enjoy life smiling smiley
Re: Infill Problem
December 03, 2013 12:59PM
Many thanks for yr reply, i'll try and let you know.
Re: Infill Problem
December 04, 2013 04:31PM
I'm back to ask again some help… sad smiley
there is no way, here is some pics of my last print, 10x10 cube but it looks like a blob.
any idea? it seems that the i3 extrude to much plastic but i've tested again the e-step and looks ok… Pls help me my house is full of useless cube!
Edited 2 time(s). Last edit at 12/05/2013 02:30AM by Alex2099.
open | download - Foto del 04-12-13 alle 22.21.jpg (146.2 KB)
open | download - Foto del 04-12-13 alle 22.22.jpg (111.9 KB)
Re: Infill Problem
December 05, 2013 04:21AM
You can't print 0.5 layer height with a 0.5 nozzle. Layer height should be Max 80% of nozzle size.
I normally print 0.25 layer with 0.5 nozzle. Can do 0.35 to, but i never go over that.
So try with a layer height of some 0.2-0.35 :-)
Jesper
Re: Infill Problem
December 05, 2013 12:44PM
lower the layer height, drop the temp to 210, and try a 20x20 cube. 10x10 is not cooling enough between layers.
Re: Infill Problem
December 07, 2013 08:00AM
Just want to thank you all, that's my actual printing quality and i'm super happy.
soon i'll try also smallest nozzle.
In order to help who will be in my same condition here is the slic3r config file of my printer
Thanks again
bye
open | download - Foto del 07-12-13 alle 13.52.jpg (62.7 KB)
open | download - config.ini (3 KB)
Re: Infill Problem
December 21, 2013 01:05PM
Hi Alex,
So, what exactly did you end up doing to get the improvement shown?
Bob
Re: Infill Problem
December 22, 2013 01:15PM
Hi Bob,
1st of all I've changed a parameter in slic3r:
reduce the Solid infill threshold area on infill form: I put 1 mm2 / default is 70 mm2 so all the pieces under that value will be filled and my printer cannot fill more than 4/5 layers in a row.
2. reduced a little bit the temperature (215)
3. and reduced the layer height to 2 mm for raw thing and 0,8 for finest…
let me know the result.
Ciao
Re: Infill Problem
December 22, 2013 09:35PM
Hi Alex,
I too have problems with top layers, bottom too. This thread helped somewhat. I made the following changes from default settings: Reworked my belts for "X" and "Y", used auto cooling, fill at 0.4, layer thickness 0.20, 1st layer height 150%, retraction at 3, Extrusion width at 0.4, angle for infill at 0, infill top and bottom concentric. Still have to try the threshold area adjutment, that is nex time.
I use PLA, 1.75mm, and a 0.35 nozzle with temp from 185C - 190C.
Results were pretty good, fairly good bottom and a great top. Bottom seems real critical in "Z" distance between head and bed. Still have blobs/stringing so need more work on Retraction.
Need to find solution to a weak few layers that keep recurring about 1/8" up from bed on all my prints. I use rectilinear infill for fill at 40%.
In any event your thread topic has helped me improve. There are a lot of subtle adjustments...
Bob
