Bottom layer not solid
Posted by amr_dwarf
January 16, 2014 02:59AM
I just completed the build of a Mendel90. It works well and I am surprised with the good results without any real tweaking.
But as I am new to this there is a few things I need to ask.
Looking at the attached picture of a bottom layer one could see places where it is not solid. What settings should I look at to correct this?
Using Slic3r and Pronterface printing from SD-card.
Cheers
Dwarf
open | download - DSC_0390.jpg (110.4 KB)
Re: Bottom layer not solid
January 29, 2014 01:27AM
Use rectilinear infill for bottom layer, check your E steps and check is filament skipping.
January 29, 2014 12:33PM
I am using rectilinar infill for bottom layer.
The E-steps are calibrated and double checked.
How to I check if filament feed is skipping? I can not see it and everyting else in the print looks nice.
January 29, 2014 01:03PM
What are your retraction settings? It looks like you are having an issue where the area to fill is narrow and your angles are oblique. I notice that on my prints, there is retraction done in these situations, but they are short moves - so it needs to be ready to print again quickly. Perhaps you are either 1) retracting too far, or 2) you have too small of a minimum distance for retraction.
Just a guess.
January 29, 2014 02:17PM
My settings for retraction is in the attached image.
Maybe "Minimum travel after retraction" is what needs to be adjusted?
Please keep the input comming, it is helpful!
open | download - retraction.png (72.6 KB)
