Print looks wierd. January 20, 2014 06:12AM |
Re: Print looks wierd. January 20, 2014 09:52AM |
Re: Print looks wierd. January 20, 2014 10:33AM |
Re: Print looks wierd. January 21, 2014 07:20AM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: Print looks wierd. January 21, 2014 11:15AM |
Re: Print looks wierd. January 22, 2014 02:20PM |
Re: Print looks wierd. January 22, 2014 02:24PM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Print looks wierd. January 22, 2014 02:59PM |
Re: Print looks wierd. January 24, 2014 05:10PM |
Re: Print looks wierd. January 28, 2014 03:22AM |
Re: Print looks wierd. January 28, 2014 04:50PM |
Re: Print looks wierd. January 29, 2014 03:20AM |
Ohmarinus
I have a problem with Cura where it doesn't print single-wall objects with thin walls like the 20x20 thin wall cube. It has 0.5mm walls and my nozzle size is also 0.5mm
The strangest thing is that Cura makes all my prints come out nicer and smarter, but Slic3r does however manages to make more out of thin-walled objects I try to print.
With the thin-wall cube, Cura just says printing time 0 minutes and doesn't show anything being printed. I have no idea how this works, but I can't find out how to 'trick' cure into printing the object without having to change very important settings.
Your lampshade looks very nice, I think your settings are quite ok. Is the inside of the lampshade also correctly printed?
Re: Print looks wierd. January 29, 2014 03:44PM |
Re: Print looks wierd. January 29, 2014 04:52PM |
Re: Print looks wierd. January 29, 2014 06:05PM |
Re: Print looks wierd. January 30, 2014 02:15AM |
Re: Print looks wierd. January 30, 2014 09:39AM |
Re: Print looks wierd. January 30, 2014 10:00AM |
Re: Print looks wierd. January 30, 2014 10:14AM |
Re: Print looks wierd. January 30, 2014 10:51AM |
