Printing ABS Temp Issue: Please Help !!! February 21, 2014 04:16PM |
Re: Printing ABS Temp Issue: Please Help !!! February 21, 2014 04:27PM |
Re: Printing ABS Temp Issue: Please Help !!! February 21, 2014 04:36PM |
Re: Printing ABS Temp Issue: Please Help !!! February 21, 2014 04:43PM |
Re: Printing ABS Temp Issue: Please Help !!! February 21, 2014 04:56PM |
Janski
Normally, I found that when I click Set Temp in pronterface, the printer heats up to the temp stated, but then it slowly start to fall.
If i set this to "0" in slic3r, would i then have to keep on clicking set temp in pronterface? or will it keep the temp for the duration of the print time?
Re: Printing ABS Temp Issue: Please Help !!! February 24, 2014 06:47PM |
Re: Printing ABS Temp Issue: Please Help !!! February 24, 2014 07:47PM |
jbernardis
Forget the 0 in slicer - it's not a good idea. You can preheat all you want from pronterface, but once you start printing, the G code will take over temperature management. If the G code says 0, the temperature will fall to 0.
Re: Printing ABS Temp Issue: Please Help !!! February 24, 2014 10:31PM |
Re: Printing ABS Temp Issue: Please Help !!! February 24, 2014 10:35PM |
waitaki
I set my temps in slic3r to 0 and 0 so I can manually set them in Pronterface. When temp is reached, the printer starts and temp is maintained accurately throughout the job.
Re: Printing ABS Temp Issue: Please Help !!! February 24, 2014 11:55PM |
waitaki
Bit puzzled by that?
Re: Printing ABS Temp Issue: Please Help !!! February 25, 2014 12:41AM |
Re: Printing ABS Temp Issue: Please Help !!! February 27, 2014 02:18PM |
Re: Printing ABS Temp Issue: Please Help !!! February 27, 2014 02:51PM |
Admin Registered: 17 years ago Posts: 1,472 |
