First Print Slants in Y Direction?
Posted by logiwan992
February 22, 2014 01:40AM
So I just got my prusa i3 up and running started my first test print of a cube. Everything went well for the first layer but once it moved on to the next layer the print started to slant in the y direction. Here is a picture of what happened.
Is this something wrong with the firmware or is it something physically wrong? What should I change to fix this? Any help is greatly apretiated.
Re: First Print Slants in Y Direction?
February 22, 2014 02:03AM
How much is your acceleration?
February 22, 2014 02:12AM
DEFAULT_ACCELERATION 3000
DEFAULT_MAX_ACCELERATION (9000,9000,100,10000)
February 22, 2014 02:18AM
Try to lower down the max acceleration in half and try again to print..
have you adjust your stepper driver boards?
Edited 1 time(s). Last edit at 02/22/2014 02:21AM by pelo13.
February 22, 2014 02:31AM
10% into print after changing the acceleration. Looks great so far. Thanks for the help.
February 25, 2014 05:06PM
So changing the acceleration helped for small objects but not for larger ones. For instance, when I try printing wades large gear it messes up. It prints fine for the first 3 layers, but always on the 4th it gets misaligned usually in the y direction. I tried tightening the belt on the y-axis and turning up the power on the stepper driver. Even with these changes it still gets misaligned on the 4th layer. What else could be causing this?
February 26, 2014 03:08PM
logiwan992
Incorrect v-ref on pot, axis binding, driver getting too hot, acceleration still too high, jerk wrong, loose pulley, belt slipping...
