Hello fellows,
Been working with the K8200 for a while now.
And mostly truddling along quite nicely.
I have found one neat
solution, to keeping the print stick to the plate.
Sugar-water...
...in a suitable container (I use an empty shampoo flask).
A sprayflask water to thin it (more often than adding more).
A thin plastic comb, to spread it out evenly (a spatel etc doesn't work as well, a brush would get clogged fast).
Then I saw there were these clips to print and use in conjunction with the plate (glass bed).
This is at Vellemann, the ones delivering the K8200.
How are they meant to be used...?
And the problem...
...I guess most would cry havo... crosstalk.
But it popped up quite suddenly and I find it hard to really warm to the idea as such at all.
The problem is that the X-axis jumps ten mm left when looking for the endstop.
And then decide that this new position is the endstop.
I can move left and right in relation to this endstop.
Pushing the Home X button create a new endstop, ten mm left of wherever X is at that moment.
And what do I run then...
W7
Repetier-Host 0F95
Slic3r 1.0.0RC2
Vellemann K8200
What is wrong?
I am an incurable optimist. The vaccine did not bite.
