Finding the right temperature March 09, 2014 11:44AM |
Re: Finding the right temperature March 09, 2014 10:41PM |
Re: Finding the right temperature March 10, 2014 05:06PM |
Admin Registered: 17 years ago Posts: 1,472 |
Re: Finding the right temperature March 10, 2014 05:12PM |
Re: Finding the right temperature March 10, 2014 05:29PM |
It's possible that the J Head that you have is a cheap clone rather than an original J Head. Can you link to the Amazon product that you purchased? Can you also post a picture of the hot end you have, so we can see if it matches what you ordered?Quote
TheBearF8
Currently using a
3D Printer J Head Hot End Kit for 3.0 mm Filament - 0.35 mm, Resistor, Thermistor, Teflon Tubing (from Amazon)
This is definitely a cheap J Head clone, and will likely have problems with printing anything other than ABS. See: [jheadnozzle.blogspot.com]Quote
TheBearF8
But I have also ordered a
Getech 3D Printer RepRap Assembled J-Head Hot End Hotend for 3mm filament ABS/PLA for Prusa Mendel. 4 options Nozzle Size:0.3mm,0.35mm,0.4mm,0.5mm (0.3mm Nozzle) (also from Amazon)
Re: Finding the right temperature March 10, 2014 05:42PM |
Re: Finding the right temperature March 10, 2014 06:18PM |
They are selling that hot end as an original hotends.com hot end, so the hot end you received should match that image exactly (5 slots in the PEEK, compact brass heater block/nozzle, red PTFE liner, etc.).
The original hot end that you got should have no problems printing all of those materials if you use the proper temperatures, though printing nylon will bring temperatures close to the max operating temperature of the hot end (this is true of any hot end that uses PEEK and PTFE). Do you have a fan cooling the PEEK for printing PLA? Without it, PLA will usually jam.Quote
TheBearF8
Can you then recommend a link where I can buy a decent Hot End that will print different materials esp. ABS, PLA, Nylon and NinjaFlex
Re: Finding the right temperature March 10, 2014 06:29PM |
Re: Finding the right temperature March 10, 2014 06:34PM |
In this case, I would try getting an exchange on the original hot end you purchased. With a fan blowing on the PEEK, it should have no problem printing PLA.Quote
TheBearF8
I'm attaching two photos
( 0892 )
The first is the original hot end I just pulled it out of the holder
Yes I have a 12VDC fan blowing on the PEEK (The black tube) yes
The Other hot end I was waiting for just arrived and so I photographed it ( 0893 )
The only print I have managed to get right was PLA without the fan at around 205 oC
Everything else has failed, including the latest attempts with PLA using a fan
Thanks again
Re: Finding the right temperature March 10, 2014 06:45PM |
Re: Finding the right temperature March 10, 2014 06:56PM |
I recommend getting a J Head from the original creator, at hotends.com.Quote
TheBearF8
Thanks
I'll try getting a replacement
Can you recommend a link where I could perhaps buy a replacement also ?
The best way is to start at the lower end of the recommended printing temperatures (see PLA, ABS), and increase temperature as necessary to get reliable extrusion.Quote
TheBearF8
What is the right way to find the correct temperature of a material. Is there a proper procedure or process ?
Ideally at Z=0, the hot end should just barely be touching the glass. If this causes issues (because your glass isn't perfectly flat or something), you can set Z=0 to be about 0.1mm above the glass using a piece of thin paper, and set your slicer to offset Z by -0.1mm.Quote
TheBearF8
Also, When Z is at home, what exactly should be the height between the tip of the hot end and glass of the table ?
