direct drive extrusion and consistent flow March 09, 2014 05:46PM |
Re: direct drive extrusion and consistent flow March 10, 2014 01:04PM |
Re: direct drive extrusion and consistent flow March 10, 2014 04:58PM |
Admin Registered: 17 years ago Posts: 1,472 |
Re: direct drive extrusion and consistent flow March 10, 2014 06:55PM |
Re: direct drive extrusion and consistent flow March 11, 2014 02:07AM |
Re: direct drive extrusion and consistent flow March 22, 2014 09:59AM |
madscifi
What you've described and what appears in the pictures could be caused by the stepper motor configuration for the extruder stepper. It looks as though the stepper is not microstepping properly.
Some questions:
1) What stepper motor controller are you using?
2) What is the number of microsteps that you have configured on your stepper controller?
3) What is the current that you have set on your stepper controller?
4) What voltage are you using to drive the stepper motor?
Re: direct drive extrusion and consistent flow March 22, 2014 10:07AM |
Re: direct drive extrusion and consistent flow March 22, 2014 10:31AM |
bilsch
The guy I purchased the printed parts found a very interesting link on a solidoodle forum and it looks like there is another experiencing very similar effects to what I am. Sadly, I don't think I can get 1/32 on a ramps 1.4 board - anyone know if otherwise?
[www.soliforum.com]
Re: direct drive extrusion and consistent flow March 23, 2014 03:20PM |
Re: direct drive extrusion and consistent flow March 23, 2014 04:14PM |
Lots of options and easy to screw up
madscifi
So you fixed the problem by switching the driver board for one that support 1/32 of a step? Or something else?
Re: direct drive extrusion and consistent flow March 23, 2014 05:56PM |
Re: direct drive extrusion and consistent flow April 09, 2014 02:59PM |
bilsch
