Hi everybody, I'm relatively new to all this and have only had my printer running since the middle of January. I'm about this close to giving up on 3D printing: ||
I realize that the distance between lines changes with varying resolutions and screen sizes, but you get the point...
So I have a Prusa i3 from norcal-reprap. It seems to be of mostly acceptable quality, although the Z axis ends are warped and dont hold the linear bearings in a concentric fashion. But thats another story...Anyway, the problem is that I am RARELY able to finish a print without the extruder jamming. Randomly the extrusion will stop and the hobbed bolt will start chewing up the filament. There is no telling when this will happen. Sometimes it happens right at the beginning while printing the brim (using Cura), sometimes it fails in the middle or near the end of the print, and yesterday it failed right when it got the the bridge layer of the 50mm bridge torture test. I originally was using black ABS from matterhackers (3mm dia. by the way), and thought crappy filament was the problem. I had no evidence to back up that assumption other than the printer kept jamming, and that the ABS would not dissolve at all in acetone, even after more than a week (though it would expand and become like pudding). Their filament appeared fine visually and had an acceptable variance in diameter, but it was black and I've heard horror stories about black. I now believe the filament may have acceptable. I switched to makerfarm orange ABS ordered directly from their website, and the printer worked great for 4 prints! but then the jamming returned without me changing any settings. I was literally printing the same part over and over, hitting the print button for the same gcode file, and the thing all of a sudden strips the filament halfway into a print. I am using a clip and a bit of paper towel as a filament wipe to keep FOD from entering the nozzle (it is just brushing up against the filament and does not add any resistance to the filament being drawn into the extruder), and in addition I have a plastic bag that my jeans came in covering up the entire spool of filament to prevent dust from settling on it (its the perfect size and clear, if you order jeans online give it a shot).
While the printer was working, I had it doing perimeter at 30mm/s and infill at 60mm/s. I don't know if that is a reasonable speed or not, but it did work for a while. Temperature at first, when it was working, was either 235C or 240C. Oh right, I used ceramic non conductive CPU heatsink compound to cement the thermistor into the nozzle, and did PID autotune (sprinter). The heater resistor is wrapped in a single layer of aluminum foil for a snug fit. Extruder temperature appeared to be stable during prints, usually within 1C but sometimes straying 2C high or low. I tried lowering the temperature to 230C, and it failed. I tried printing a part at 248C, and it failed. Everything in between fails. My man parts convinced me to crank that bad boy up to 260C (!!) but within a minute I came to my senses and lowered it to 248C, and later in the print it failed. I have verified in my firmware that the upper temperature limit is 275C, so there is no way the extruder should be doing the emergency shutdown thing. I have selected the correct thermistor in the firmware. My esteps in the firmware are calibrated to within half a mm over a distance of 50mm, which should be close enough to fine tune with the extrusion multiplier. Using M105 I have verified at the first sign of failure that the temperature is as I had specified in the gcode, and it is. I don't have a way to verify the temperature with a thermocouple, but I did put a wee bit of orange ABS on the side of the nozzle, and over time it has become black, so I think the extruder is hot enough that it should be extruding. The plastic does not come out looking watery, so I don't think it is too hot either. Air extruding results in a nice shiny 0.5mm diameter noodle (this is a 0.4mm nozzle), and it seems to extrude nearly straight down. The noodle is circular, not oval shaped (confirmed with calipers).
The nozzle doesn't seem to entirely plug up as I would expect. If I pause the print, pull the filament out and clip off the chewed up portion, and put it back together it will continue printing happily for a while (usually tens of minutes) before jamming again. I've actually found that no matter if I clean the nozzle out or not, it inevitably fails at some point in the near future, and it doesn't particularly seem to matter if I simply clip the chewed up part and immediately continue, or spend a bunch of time trying to clean out the plastic thats already in the extruder. I can keep trimming off filament and reloading it when it jams every so often, and it does actually make it through a print (albeit with defects from where it was paused for 30 seconds while I fixed the extruder). I have tried the suggested method of cooling the nozzle to 140C and reversing the filament to pull all the plastic out, but so far have found this to not work quite as advertised. My best result was at 135C, and a reverse speed of 30mm/min (slower than I can go by hand), but the filament still ended up snapping with a bit left in the extruder. It did make a very long stringy thing and I'm sure pulled out most of the plastic with it, but there was still some left. A hotter temperature will melt the filament in half, and a lower temperature snaps sooner. I repeated this process 5 times in a row, and afterwards it still failed to print a complete part without jamming.
I have tried lowering the print speed to 15mm/s perimeter, 30mm/s infill, and it still fails. I suppose I could try going slower, but I hear about people going 80 or 90 mm/s and I see no reason why I should have to go below 30. Is 30mm/s unrealistic?
The hobbed bolt appears to be of very high quality. The teeth are evenly spaced and the groove does not wander back and forth as the bolt rotates. I clean the teeth out each time it strips the filament. I have gone so far as using index cards as washers to center the hobbed bolt over the extruder opening. I have tried adjusting the extruder spring tension bolts from extremely loose, to absurdly tight completely compressing and crumpling the spring coils over top of eachother, and it still fails. I have listened to the stepper motor and it is not skipping steps. I have checked that the extruder gears are not slipping on the motor shaft or hobbed bolt (but it is chewing filament so you already knew thats not the problem). I have checked that the filament can be pushed through to the bottom of the extruder, and while it cannot go ALL the way, it is fairly close I think. I believe the last bit of distance is because there was still some small quantity of filament in there. It certainly goes down past the top of the brass and into the melt zone. I find it fairly difficult to extrude by hand, but the motor seems to have no trouble. That is, until it randomly strips the filament again. I currently have it set up to slightly underextrude so that I can be certain it is not overfilling plastic and plugging up the nozzle by dragging through previous layers. Solid layers have a very slight gap between the infill.
In case I missed anything, here is a summary of the printer: it is fitted with the hinged accessible extruder, guidler, and a genuine J-head from hotends.com (I know it is genuine because I broke the PEEK on the original one trying to disassemble it while it was cold, and bought an entire new J-head from Brian). Electronics are sanguinololu with pololu drivers and sprinter firmware. Firmware max temperature set at 275C. Thermistor cemented in using electrically nonconductive ceramic heatsink compound. Heater resistor wrapped in aluminum foil for a very tight fit. Filament was originally black 3mm ABS from matterhackers, and is now orange 3mm ABS from makerfarm, both of which I am experiencing these jamming issues with. Filament roll is covered with a bag to keep dust off, and it passes through a paper towel clipped around the filament immediately above the extruder. It is very very easy to slide the paper towel clip thing back and forth on the filament, so I am 100% certain any resistance added by it is negligable....that's about all I can think of.
So seriously, WTF is wrong with this thing. I've been fighting with it several hours each day, and practically all waking hours on the weekends, for nearly two months now. I'm about to throw most of it in the trash and use the steppers and electronics for other stuff. If anyone has ANY ideas, please don't hesitate, because at this point I'm completely out of ideas to try other than lowering print speed to a snails pace.
