Blistering/Lifting on first layer March 11, 2014 09:27AM |
Re: Blistering/Lifting on first layer March 11, 2014 11:31AM |
Admin Registered: 17 years ago Posts: 1,472 |
Re: Blistering/Lifting on first layer March 11, 2014 12:41PM |
amrbekhit
- I've tried printing with the heated bed set to 65, 70 and 75 degrees.
...couple of photos illustrating the phenomenon
Re: Blistering/Lifting on first layer March 11, 2014 12:44PM |
Re: Blistering/Lifting on first layer March 11, 2014 03:28PM |
Most heated beds have the thermistor located under the heating element rather than on top of the glass. This means that the glass temperature is usually a fair bit lower than the thermistor is reading. Although it does appear in his picture that the thermistor is touching the bottom of the glass, I would not be surprised if it does still read higher than the temperature of the top surface of the glass. However, it would not hurt to try setting the heated bed slightly coolerQuote
ShawnT98027
To print PLA on heated glass, make sure your heated glass is actually 60c... then enjoy Happy Printing !
Re: Blistering/Lifting on first layer March 12, 2014 12:37PM |
NewPerfection
Re: Blistering/Lifting on first layer March 12, 2014 07:04PM |
Re: Blistering/Lifting on first layer March 12, 2014 07:54PM |
Re: Blistering/Lifting on first layer March 15, 2014 06:03AM |
Re: Blistering/Lifting on first layer March 17, 2014 04:43AM |
Re: Blistering/Lifting on first layer March 17, 2014 07:14PM |
Re: Blistering/Lifting on first layer March 18, 2014 04:05AM |
