First time 3D printer user... Struggling with ABS and starting layers
March 12, 2014 06:23PM
Hi guys,
Bought a 3D printer the other day and it arrived today I set it up and calibrated it as it says on the machine and use ReplicatorG to slice the STL file and print it. Here's the settings i'm using...
Nozzle Temp - 225oc
Bed Temp - 110oc
Bed surface - Blue painters tape
Material - 1.75mm ABS
Feedrate - 35mm/s
Rapid rate - 40mm/s
Layer Height - 0.4mm
What it will do is start fine and begin to print it got to 35% and then it just sort of grabs the part and rips it away from the bed? I haven't a clue why I've tried a few different settings and to no joy. It's also rough as a dogs bumhole for edges. Here's the model I'm printing...
I am printing the part face down (tabs in the air) and here's how it's looking...
This is the machine I purchased...
[www.ebay.co.uk]
I need some urgent assistance/advise as I have stupidly gambled some other peoples money on this also lol.
Nick
Re: First time 3D printer user... Struggling with ABS and starting layers
March 12, 2014 09:39PM
If I was you, I would start by printing some of the calibration models first to fine tune your printer.
_______________________________________
Waitaki 3D Printer
March 13, 2014 02:57AM
Where do I find calibration models matey smiling smiley.
March 13, 2014 12:26PM
March 13, 2014 09:22PM
you'll find some here...
[www.reprap.org]
Waitaki 3D Printer
March 13, 2014 11:58PM
I might recommend the following changes:
Nozzle Temp - 240oc
Bed Temp - 110oc
Feedrate - 15mm/s
Rapid rate - 15mm/s
Layer Height - 0.1mm
See if this helps. Good luck!
March 14, 2014 05:45AM
Thanks for the replies guys. Tried again last night
Nozzle: 227
Bed: 117 and 110
Layer height: 0.1
Feed rate: 40mm/s
Raft/Support: on
And it got to this far then lifted off the bed?
[s121.photobucket.com]
March 14, 2014 06:23AM
ABS shrinks and warps like that. You would be better off printing something like this with PLA.
In my own experience with printing ABS on print stickers (clear packaging labels). Is to polish the sticker to a shine using a cloth, warm water and some dishwashing detergent. This way I get way better results.
If you want it 100% good, you could try making an ABS slurry.
[www.instructables.com]
(Make sure your acetone is pure enough or it wont work)
March 14, 2014 08:18AM
I found I get better adhesion directly on the glass. Started with blue painters tape with purple Elmers gluestick.
Now I print at 240c nozzle and 135c bed. First I clean it with Windex until it squeeks then 97% isopropyl alcohol. Prints stick like they are epoxied to the glass until it cools then they pop right off. Need to get another piece of glass cut so I can swap and keep printing.
Also check your starting nozzle height, I bought feeler gauges, took the .09, .1 and .11 and color coded them red, green and yellow. I fought for days trying to get things to stick when I noticed I had pulled the .09, .1 and .11 INCH feeler gauges!! Switched to .1MM, reconfigured the autoleveling offset and so far great prints straight on the glass
March 14, 2014 08:55AM
Epic advice guys. Should I try printing directly on to the metal bed? Mines limited up to 120 degrees I think. I don't think I could push it to 135.
March 14, 2014 09:20AM
I use glass bed at 110c with purple elmers stick glue in a thin layer. Prints stay on untill the glass cools down and they pop off.
March 14, 2014 10:10AM
I'm in the uk I'm assuming a pva glue would suffice?
March 14, 2014 01:45PM
I would try a cheap piece of glass cut down to fit, glass is easy to cut, just watch a couple youtube videos on it.
Nice thing about printing on glass is the SMOOTH finish
March 14, 2014 06:49PM
Yes,exactly. Glass should be a default inclusion on a heat bed. I use 3mm and a couple of coats of hairspray.
Waitaki 3D Printer
March 19, 2014 05:30PM
Yes PVA (kids craft glue) works. Im a new user too and had similar issues. watered down PVA wiped onto the glass worked great . It kinda muckies the glass but the part really holds to it.
Getting the space from the nozzle to the glass plate correct and level seems pretty important too. Once the first layer gets pressed onto the surface the others seem to behave.
March 26, 2014 12:45PM
Sorry for the late reply I wrapped the machine in tin foil to keep as much heat as possible in that helped slightly I've managed to print 8 things so far but the problem being you have to print at least 4 failures before the machine gets on a printing streak with no problems.
