Universal 3D printing filament spool standard 2014 March 13, 2014 09:59AM |
Re: Universal 3D printing filament spool standard 2014 March 13, 2014 10:37AM |
Re: Universal 3D printing filament spool standard 2014 March 13, 2014 12:04PM |
Re: Universal 3D printing filament spool standard 2014 March 13, 2014 12:13PM |
Re: Universal 3D printing filament spool standard 2014 March 13, 2014 12:25PM |
Re: Universal 3D printing filament spool standard 2014 March 13, 2014 01:17PM |
Re: Universal 3D printing filament spool standard 2014 March 13, 2014 01:19PM |
Re: Universal 3D printing filament spool standard 2014 March 13, 2014 01:28PM |
Re: Universal 3D printing filament spool standard 2014 March 13, 2014 02:00PM |
richrap
All challenges, but possible to change and work with. Re-spooling filament is almost the last thing you ever want to try doing, that can cause many more problems than the ones already identified.
Rich.
Re: Universal 3D printing filament spool standard 2014 March 13, 2014 02:13PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Universal 3D printing filament spool standard 2014 March 13, 2014 02:41PM |
Re: Universal 3D printing filament spool standard 2014 March 13, 2014 02:46PM |
Re: Universal 3D printing filament spool standard 2014 March 13, 2014 03:03PM |
Re: Universal 3D printing filament spool standard 2014 March 13, 2014 03:24PM |
richrap
@Sublime -
I have seen many more then ZERO issues on various machines using tightly wound 3mm filament, even ones using bowden feeds. But much of that also depends on how the filament has been treated going onto the spool, some get wound quickly when still warm, squashed oval, strained, kinked or twisted.
I would not want to bet a machine like the Ultimaker 2 with a direct drive bowden would not have issues with a coil like this, I would be very happy to be proved wrong, but tightly wound coils of PLA have caused me and others plenty of issues in use.
The less changes we need to make the more likely manufacturers are to implement something, I agree cardboard and a 'standard' mounting hole has to be a good starting point, but I will also look out for bigger inner coils too.
Re: Universal 3D printing filament spool standard 2014 March 13, 2014 04:35PM |
richrap
@vreihen - Anyone can make their own standard, this is more about an 'open mechanical standard' hopefully without using lots of plastic casings that are not designed to be refilled and only contain ~300g of plastic filament costing $80+
This 'standard' should not stop people branding up the spools however they like, labels, printed cardboard with logo's or coloured with the manufacturers 'brand' It should be quite possible to identify a manufacturer and have a universal mechanical standard. In fact you could argue many more options for branding appear with a cardboard spool than a plastic one. Any re-branded filament should not be too hard to track-down - are you still a NO to the idea of a standard?
Sublime
I like that you can tell who manufactured the filament from the spool style. It is true a few companies use the same spools but they do not use the same spools as the bad suppliers like Esun. If manufacturers want to standardize the spools I think they need to agree to mark the spool with the manufacturers name so we as consumers can tell them apart regardless of what the re-sellers want or think. As it is the re-sellers are unknowingly letting us know who made their filament by the spool type and giving them a way to hide their supplier does not sit well with me.
toybuilder
@vreihen -- Keep in mind that spools are often NOT made by the same company that is producing the filament. There is a US-based company that makes spools for this market, and their spool is used by at least two different extrusion companies.
Re: Universal 3D printing filament spool standard 2014 March 13, 2014 05:36PM |
Re: Universal 3D printing filament spool standard 2014 March 14, 2014 07:08AM |
Re: Universal 3D printing filament spool standard 2014 March 14, 2014 07:23AM |
Re: Universal 3D printing filament spool standard 2014 March 14, 2014 10:01AM |
Re: Universal 3D printing filament spool standard 2014 March 14, 2014 12:39PM |
Re: Universal 3D printing filament spool standard 2014 March 14, 2014 12:55PM |
Re: Universal 3D printing filament spool standard 2014 March 14, 2014 08:51PM |
richrap
@vreihen - Thanks for the thoughts, I'm very aware 'generic filament' is re-sold all over for various prices. Manufacturers making good quality filament are proud to brand it, re-sellers who sell good quality filament are proud to name the manufacture, if they don't then my advice is Do Not Buy It. It's always the very first question I ask any filament seller - Do you make it, if not who manufacturers the filament / where. And what exactly does it contain, including impact modifiers etc.
Re: Universal 3D printing filament spool standard 2014 March 15, 2014 10:33AM |
Re: Universal 3D printing filament spool standard 2014 March 17, 2014 04:59AM |
Re: Universal 3D printing filament spool standard 2014 March 17, 2014 08:09AM |
Re: Universal 3D printing filament spool standard 2014 March 17, 2014 08:19AM |
whosawhatsis
I'm not sure how the cardboard spools are meant to be held together, but here's an idea I had. Two pieces of cardboard and a short piece of plastic or cardboard tube (length <= radius). You can wrap some packing tape around the center before spooling the plastic to hold the two halves in place.
It doesn't have the inner rim that Richrap's design has, but that could be added (strengthening the walls in the process) by laminating another layer of cardboard on each side, which would also prevent the core tube from working its way out. The extra wall pieces would be a good place for manufacturers to print their branding and UFID code.
Re: Universal 3D printing filament spool standard 2014 March 17, 2014 09:21AM |
ABS Nylon PLA PVA Min density (g/cm3) 1.00 1.13 1.21 1.19 Max density (g/cm3) 1.05 1.41 1.43 1.31 Avg density (g/cm3) 1.03 1.27 1.32 1.25 Kilograms on spool 1.09 1.36 1.41 1.33
ABS Nylon PLA PVA Min density (g/cm3) 1.00 1.13 1.21 1.19 Max density (g/cm3) 1.05 1.41 1.43 1.31 Avg density (g/cm3) 1.03 1.27 1.32 1.25 Kilograms on spool 1.10 1.36 1.42 1.34
ABS Nylon PLA PVA Min density (g/cm3) 1.00 1.13 1.21 1.19 Max density (g/cm3) 1.05 1.41 1.43 1.31 Avg density (g/cm3) 1.03 1.27 1.32 1.25 Kilograms on spool 1.18 1.46 1.51 1.43
ABS Nylon PLA PVA Min density (g/cm3) 1.00 1.13 1.21 1.19 Max density (g/cm3) 1.05 1.41 1.43 1.31 Avg density (g/cm3) 1.03 1.27 1.32 1.25 Kilograms on spool 1.13 1.40 1.46 1.38
ABS Nylon PLA PVA Min density (g/cm3) 1.00 1.13 1.21 1.19 Max density (g/cm3) 1.05 1.41 1.43 1.31 Avg density (g/cm3) 1.03 1.27 1.32 1.25 Kilograms on spool 1.11 1.38 1.43 1.35
ABS Nylon PLA PVA Min density (g/cm3) 1.00 1.13 1.21 1.19 Max density (g/cm3) 1.05 1.41 1.43 1.31 Avg density (g/cm3) 1.03 1.27 1.32 1.25 Kilograms on spool 1.17 1.45 1.51 1.43
ABS Nylon PLA PVA Min density (g/cm3) 1.00 1.13 1.21 1.19 Max density (g/cm3) 1.05 1.41 1.43 1.31 Avg density (g/cm3) 1.03 1.27 1.32 1.25 Kilograms on spool 1.12 1.39 1.45 1.37
Re: Universal 3D printing filament spool standard 2014 March 17, 2014 01:21PM |
Re: Universal 3D printing filament spool standard 2014 March 17, 2014 06:03PM |
Re: Universal 3D printing filament spool standard 2014 March 18, 2014 06:40AM |
whosawhatsis
Does someone have links to some better cardboard spools? All of the ones I've seen are worse designs than what I posted.
Even if there are better designs (and I hope there are), it doesn't hurt to have a version that can be made by anyone with a lasercutter and a way to cut lengths of tube.
