Re: Universal 3D printing filament spool standard 2014 March 18, 2014 12:48PM |
Re: Universal 3D printing filament spool standard 2014 March 18, 2014 04:51PM |
nothinman
Don't get me wrong, I'm not criticising your design, it's actually pretty interesting. It's just that it's actually hard to make tooling for it and it requires a lot of assembly.
If you're making one spool then it's fine. If you cut it with a laser -- even better.
But again: why would YOU want/need to make spools?
Marcin
Re: Universal 3D printing filament spool standard 2014 March 19, 2014 12:24AM |
Admin Registered: 17 years ago Posts: 1,472 |
richrap
What amount of filament do people like? - for me 750g to 1Kg is about ideal, below that it's a pain and above to about 1.5Kg is okay, but not much more.
Re: Universal 3D printing filament spool standard 2014 March 19, 2014 01:02AM |
Outliers like the above comment notwithstanding, I think 1kg is the happy medium.Quote
richrap
Re: Universal 3D printing filament spool standard 2014 March 19, 2014 01:20PM |
Re: Universal 3D printing filament spool standard 2014 March 19, 2014 06:33PM |
Chri
Instead of making an additional standard , why not to try to use existing spool designs and define one/two (1kg/2.2kg) as standard ?
Chri
Re: Universal 3D printing filament spool standard 2014 March 19, 2014 07:31PM |
Re: Universal 3D printing filament spool standard 2014 March 19, 2014 08:01PM |
Chri
Finding one single design for all Printers won`t be very easy, people with small printers prefer small rolls (mobility), people with large printers large rolls.
So if there only should be one size, what would be the optimal amount of filament per roll?
Re: Universal 3D printing filament spool standard 2014 March 19, 2014 09:26PM |
Re: Universal 3D printing filament spool standard 2014 March 20, 2014 11:48AM |
richrap
General consensus from talking to various people seems to be that a narrow spool is better than a wide one, for better feeding and general handling both during manufacture and use bu the customer. - Anyone got any views on that?
And as a side note - I mentioned on my blog that Makerbot seems to have a new size spool and interestingly they also seem to have gone narrower (now 40mm wide instead of 76mm) and bigger diameter (250mm rather than 200mm), I can't tell what the internal filament diameter is (does anyone have a new Makerbot spool?)
Re: Universal 3D printing filament spool standard 2014 March 20, 2014 12:39PM |
Re: Universal 3D printing filament spool standard 2014 March 23, 2014 09:31AM |
Re: Universal 3D printing filament spool standard 2014 March 26, 2014 09:41AM |
Re: Universal 3D printing filament spool standard 2014 March 26, 2014 12:41PM |
Re: Universal 3D printing filament spool standard 2014 March 26, 2014 01:01PM |
Re: Universal 3D printing filament spool standard 2014 March 26, 2014 01:20PM |
whosawhatsis
Perhaps it we should define one "full-width" design for 1kg, then say that other sizes can be used. For instance, a 1/3W version for a 1/4kg spool that you can fit 3 of in the space of one 1W spool and a 2W that should hold about 5lb (2.27kg). Then a machine built for a 2W spool could hold 1x2W, 2x1W, 6x1/3W, 1x1W+3x1/3W, etc.
- I was told by a few filament suppliers the exact opposite of this, a smaller width causes less issues with tangles.Quote
Makerstash
"larger widths (aka a larger "Traverse"). The reason is it reduces the number of times the filament needs to cross back over itself."
- I do like the idea and that's exactly where I started from - can we make a re-loadable spool? but quickly this looks less and less likely as you start talking to suppliers and thinking about usability along the chain.Quote
eades850
"This enables supplies to be purchased in coils (lower cost) and then transferred to feed spools"
Re: Universal 3D printing filament spool standard 2014 March 26, 2014 01:35PM |
Re: Universal 3D printing filament spool standard 2014 March 26, 2014 03:33PM |
whosawhatsis
RIchrap, are you sure about the 120mm core thing? I looked at some of mine, and they had cores closer to 100mm. This is a standard size for cardboard mailing tubes that would make a good source of hubs for these spools.
Re: Universal 3D printing filament spool standard 2014 March 26, 2014 07:53PM |
Re: Universal 3D printing filament spool standard 2014 March 27, 2014 07:54AM |
Re: Universal 3D printing filament spool standard 2014 March 27, 2014 02:29PM |
Re: Universal 3D printing filament spool standard 2014 March 27, 2014 10:00PM |
Re: Universal 3D printing filament spool standard 2014 April 01, 2014 08:02AM |
Re: Universal 3D printing filament spool standard 2014 April 01, 2014 11:42AM |
Re: Universal 3D printing filament spool standard 2014 April 01, 2014 04:05PM |
Re: Universal 3D printing filament spool standard 2014 April 02, 2014 10:52AM |
eades850
It works for me. My only question is the material. Are you looking at a cardboard/cardstock composition or plastic? Hence, is it reusable, returnable, recyclable or what?
Re: Universal 3D printing filament spool standard 2014 April 04, 2014 12:33AM |
Re: Universal 3D printing filament spool standard 2014 April 04, 2014 06:36AM |
Chri
If you use cardboard, how do you ensure that the roll is running smooth at the outside ?
Alot of people are running the rolls sitting on four bearings (Prusai I2`s , Mendelmax, ... )
Chri
Re: Universal 3D printing filament spool standard 2014 April 04, 2014 07:22AM |
I think he is referring to the flange plates and not the core. Cardboard flange plates have a horrible tendency to warp and wrinkle as they age giving the people who use the 4 bearing roll bases fits if they do not transfer to a plastic spool.Quote
Chri
Chri
Re: Universal 3D printing filament spool standard 2014 April 04, 2014 11:57AM |
