Re: Universal 3D printing filament spool standard 2014 April 04, 2014 08:50PM |
Re: Universal 3D printing filament spool standard 2014 April 05, 2014 07:24AM |
Re: Universal 3D printing filament spool standard 2014 April 07, 2014 07:01AM |
eades850
OK. As I see we are down to the final nuts and bolts of this.
So far we have come up with:
Bore: 52mm
Hub: 100mm OD, 5mm wall
Flange: 200mm OD, 3mm wall
Width: 50mm ID
Composition High Density compressed cardboard
This has sufficient capacity for up to 1kg of ABS, which is the lightest.
And would be the 1W configuration.
RichRap, you have not posted in awhile. Would you care to weigh in on this and let us know your feelings and what input you have been getting from the manufacturers?
Re: Universal 3D printing filament spool standard 2014 April 08, 2014 07:47AM |
Re: Universal 3D printing filament spool standard 2014 April 09, 2014 01:21AM |
Re: Universal 3D printing filament spool standard 2014 April 09, 2014 01:48AM |
Re: Universal 3D printing filament spool standard 2014 April 09, 2014 10:06AM |
Re: Universal 3D printing filament spool standard 2014 April 09, 2014 10:07AM |
Re: Universal 3D printing filament spool standard 2014 April 17, 2014 12:52PM |
Re: Universal 3D printing filament spool standard 2014 April 17, 2014 06:04PM |
eades850
A followon to uGen's comment would be to use a biodegradable/compostable core tube of set diameter and span without sideplates, the coil being shrinkwrapped or tiewrapped to it. This core/filament package could slide onto a split-apart spool prior to unwrapping. This would combine the best of both worlds concerning production costs while minimizing disposable/returnable materials.
You can go to Lowes or Home Depot and get an idea of this technique by looking at coils of shrinkwrapped Romex residential wire.
We take these coils and slide them onto split spools for coil perimeter feeding, or lay them on a "Spinner Table" which is basically a big Lazy Susan when we want to feed from the coil center. Both techniques work very well, but my preference is the spinner table as it keeps the coil packaging intact. Using this technique with shrinkwrapped filament would help minimize dust accumulation from static buildup during use and would eliminate coil free-wheeling which can occur when perimeter feeding. And, if you have any old 16mm theater film cans you have a ready-made dust/moisture proof storage container. (Yes, I'm that old).
Re: Universal 3D printing filament spool standard 2014 April 22, 2014 11:01AM |
Re: Universal 3D printing filament spool standard 2014 April 22, 2014 11:08AM |
Re: Universal 3D printing filament spool standard 2014 April 22, 2014 01:45PM |
nothinman
Unfortunately the idea with pulling it out of the box won't work with current 3D printers, since it's coiled, and by pulling it it would effectively go into the extruder twisted. But it won't untwist there, because it will hold it tight -- so it will create more tight coils inside the box, leading to entanglement in the end.
An alternative way would be to pack it into the box in the 8-shape (series of right and left twists produce straight wire), but the box would have to be really large (or: wide), and I don't think this is a very good idea.
m.
Re: Universal 3D printing filament spool standard 2014 April 22, 2014 03:08PM |
BackEMF
BTW, I'd also like to see a sticker on each spool with the material propperties.
Material, Melt temperature, production date, shelf life, ideal storing temerature, etc., etc.
Re: Universal 3D printing filament spool standard 2014 April 22, 2014 09:41PM |
Re: Universal 3D printing filament spool standard 2014 April 22, 2014 10:01PM |
Re: Universal 3D printing filament spool standard 2014 April 23, 2014 07:14AM |
Re: Universal 3D printing filament spool standard 2014 May 03, 2014 06:28PM |
Re: Universal 3D printing filament spool standard 2014 May 05, 2014 09:22AM |
Re: Universal 3D printing filament spool standard 2014 May 05, 2014 09:23AM |
Re: Universal 3D printing filament spool standard 2014 May 05, 2014 04:01PM |
The point of developing a standard is so that these systems can be built around that standard in the future. Obviously, those that have already been designed in a way that is not compatible with the standard will either have to be redesigned or remain incompatible, but it makes it less likely that there will be a further proliferation of designs that are not compatible with one another.Quote
ecoreprap
If there is universal 3d printing filament spool standard, it will be awesomeBut I really doubt its feasibility.
1 Different 3d printers uses different spools. For example, the spool which suit Makerbot does not suit PICASO. The spool is installed inside of Picaso 3d printer,which has a very strict on the
width of the spool.Any one over 65mm is not suitable.As far as I learned, there is another brand MYWELL which have the same design.
2 The bore requirement is also different,obviously Makerbot uses bore over 52mm.
3 The idea of filament in carton box is interesting, but for 3D printing filament factory, it is not easy to achieve. I will show you one photos of production below.
Re: Universal 3D printing filament spool standard 2014 May 06, 2014 07:51AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Universal 3D printing filament spool standard 2014 September 26, 2014 04:10AM |
KingRahl
It would be nice to have a STANDARD. Although, there are many things to consider when asking the manufacturers to conform.
1. They may have a contract with a spool company and are obligated to use them.
2. They are specified to a machine that will now require that spool size and shape.
3. THEIR spool making machine can only make one kind.
I'd rather re-spool onto another. Such as filling a sewing machine bobbin or re-spooling fishing line on a reel.
Re: Universal 3D printing filament spool standard 2014 October 06, 2014 06:46AM |
Re: Universal 3D printing filament spool standard 2014 November 02, 2014 07:50AM |
Re: Universal 3D printing filament spool standard 2014 November 02, 2014 10:17AM |
Re: Universal 3D printing filament spool standard 2014 November 06, 2014 01:27PM |
Re: Universal 3D printing filament spool standard 2014 November 08, 2014 08:44PM |
Re: Universal 3D printing filament spool standard 2014 November 09, 2014 02:44PM |
Re: Universal 3D printing filament spool standard 2014 November 18, 2014 01:31PM |
