Hobbed bolt slipping April 10, 2014 01:17PM |
Re: Hobbed bolt slipping April 10, 2014 01:57PM |
Re: Hobbed bolt slipping April 11, 2014 08:06AM |
Re: Hobbed bolt slipping April 11, 2014 09:40AM |
Yes the Big gear is turning, which also means the small gear is turning.Quote
cat.farmer
are your gears turning when it is slipping?
The hot end holds the right temperature, 185 degrees, and when I manually push the filament it extrudes fine so I guess the temperature is correct.Quote
cat.farmer
is your hot end holding temp when you are extruding withthe motor?
I have not tried that yet 'cause I've heard you shouldn't move the motors when the ramps and the motor is powered. And the ramps need to be powered to heat the hot end.Quote
cat.farmer
If you move the big grear by hand to extrude, does it flow good?
the only solution I can think of is tightening the idler even more.Quote
cat.farmer
Make sure your small gear is tightened down good, and you have good tenion on the hobbed bolt.
