Prusa i3 print problem April 15, 2014 08:04PM |
Re: Prusa i3 print problem April 15, 2014 08:58PM |
Re: Prusa i3 print problem April 15, 2014 09:01PM |
Re: Prusa i3 print problem April 15, 2014 09:04PM |
Re: Prusa i3 print problem April 15, 2014 09:08PM |
Re: Prusa i3 print problem April 15, 2014 09:10PM |
cat.farmer
If the filamet being laid down and curling up or is it not being laid down?
What temp and what type of filamet?
What style hotend?
Re: Prusa i3 print problem April 15, 2014 09:13PM |
Istale
Still not sure that I understand. So you peeled that infill layer off of the first couple layers? Your first couple layers should be solid. In slic3r, set the first 2 or 3 layers to be solid before it starts infill. It appears you have zero solid bottom layers and it's trying to print infill as the first layer.
Also appears that your bed isn't level. The right side looks very thin and flat while the top left side looks... like hell.
Re: Prusa i3 print problem April 15, 2014 09:24PM |
Govanator
it starts printing the outside lines, and then its starts to infill between these lines ( where there was no layer yet, so yes it does infill as first layers)
Re: Prusa i3 print problem April 15, 2014 09:38PM |
Re: Prusa i3 print problem April 18, 2014 09:26AM |
Re: Prusa i3 print problem April 21, 2014 07:36PM |
sidhabo
Hi Gov
I'm about at same spot as you are. Printed my first 10x10 mm dice
Then going for 20x20 mm dice I get no plastic feed
I noted temp of head went down from 250 to around 210 after first layers
My guessing is that that temp is too low to get plastics feeded properly
Just trying and get it worikin now when I turned off fan auto cooling in Slicer config for Filaments
At least I have plastic feed going now and dice prints out
Need some more learning on this I guess ....
Ha det gött
Bosse
