MK3 heatbed cannot reach target temp April 22, 2014 07:05AM |
Re: MK3 heatbed cannot reach target temp April 22, 2014 04:32PM |
Re: MK3 heatbed cannot reach target temp April 22, 2014 09:18PM |
Re: MK3 heatbed cannot reach target temp April 23, 2014 03:42AM |
Re: MK3 heatbed cannot reach target temp April 23, 2014 02:17PM |
wangfei
Hi DaveX,
I connect according to this [reprap.org] (Even my one is a Mk3 the schematic on it is the same as this).
I am using a hacked PC powersupply of 420 Watt. Inside the powersupply was a total of 6 cables for 12 volt from the pcb. I have connected 3 together with a much thicker cable, which again is connected to terminal. Other 3 connected in same way to other terminal.
Do you mean that the powersupply is too small ?
Re: MK3 heatbed cannot reach target temp April 23, 2014 07:38PM |
Re: MK3 heatbed cannot reach target temp_SOLVED April 28, 2014 08:45AM |
Re: MK3 heatbed cannot reach target temp_SOLVED September 14, 2014 01:58PM |
Re: MK3 heatbed cannot reach target temp September 15, 2014 08:26AM |
