Ok so i have a I 3xl (Pursa) basically i printed for about 4 hours yesterday and with out problems. My 3rd job a big gear wheel went fine for about 30 layers then the X started binding up.
Killed the print job and tried to move it mannually and it seemed to stick in a couple spots down the axis. So now comes to the part i need help with.
I released tension on the belt to see if it was the bar or motor or belt somehow. It seems to be related to either the motor or the belt . Questions
1. Can a belt be to tight causing bind ups after a while.
2. Does this sound like the motor just got to hot.
3. Should / Can i avoid this entire issue by letting it cool off between jobs. ( note it was printing for about 6 hours stright )
Any help here would be great!
