Overhang issues
May 20, 2014 12:13AM
Hi All,
I've just installed a print fan to the hotend but overhang issues has not improved.
Please can someone advice me what I to do to improve the prints.
My printer is Prusa Mendel i3
Print layer = 0.1
PLA Temp = 190C
Heatbed = 70C
Print environment temp = 28C
Software = Slic3r
Edited 2 time(s). Last edit at 05/20/2014 10:22PM by duckfriedrice.
Re: Overhang issues
June 06, 2014 12:46AM
I think if you tried combining infill on every 1 layer it would help with those cracks you are getting.
Just in general:
I see there are also bits of plastic at the start and stopping points. There's a print you can use to easily tell how well your retratction is: [www.youmagine.com] It's quiet good because it becomes very obvious if it's working well or not.
You'll want that print to come out nicely.
Next there is temperature. You can change temperature in mid print. Sometimes 3 degrees difference can make quiet a difference.
But I'm fairly sure your prints will improve by setting infill to every 1 layer.
Edited 2 time(s). Last edit at 06/06/2014 01:52AM by TheTechnicalNoob.
Re: Overhang issues
June 06, 2014 08:14AM
Remove "detect bridging perimeters." I don't know how Slic3r changes things exactly, but it doesn't work. Thinner layers also helps, as it's taking smaller bites on each pass, so there's less area to push plastic into open air.
Realizer- One who realizes dreams by making them a reality either by possibility or by completion. Also creating or renewing hopes of dreams.
"keep in mind, even the best printer can not print with the best filament if the user is the problem." -Ohmarinus
