Anyone make a small gear with slic3r?
June 04, 2014 03:38PM
Is anyone able to print a good small gear with slic3r with filled in teeth, if so can you post your config file?
Thanks,
Dave
Re: Anyone make a small gear with slic3r?
June 04, 2014 03:46PM
Can you provide an example stl of "small" gear?
And maybe even post a picture of your attempt at a small gear?
Edited 1 time(s). Last edit at 06/04/2014 03:46PM by MrDoctorDIV.
Realizer- One who realizes dreams by making them a reality either by possibility or by completion. Also creating or renewing hopes of dreams.
"keep in mind, even the best printer can not print with the best filament if the user is the problem." -Ohmarinus
June 04, 2014 03:57PM
Thanks for your time, the bottom gear in the pic is about what I'm getting. Ive found posts on this but wasteing alot of plastic trying to change things. Any help would be appreciated.
Thanks,
Dave
open | download - small-gear-1off.stl (199.5 KB)
open | download - addon.php.jpeg (74.2 KB)
June 04, 2014 04:05PM
I'll see what I can pull tonight.
What setup do you have?
June 04, 2014 04:12PM
I have a RepRap Pro Mendel single color and running on Linux (Ubuntu). 1.7mm filament, .5mm nozzel. Thanks for your time again, you have no idea how much I appreciate it!
Dave
June 04, 2014 06:51PM
Didn't think about it until I started printing. You have a larger nozzle size, you're going to struggle with smaller parts. I've got a .3mm nozzle and it is printing perfect. I'll give you my settings anyways, but I'm pretty sure it's down to nozzle size.
First thing I would try is just printing the top of that model you gave me; lower your default extrusion width to 120%. Layer height no higher than .2mm.
June 04, 2014 07:03PM
My top didn't print as pretty as other parts, but I purposely chose my worst filament to be sure it worked well.
Edited 1 time(s). Last edit at 06/04/2014 07:04PM by MrDoctorDIV.
open | download - MrDoctorDIV-Solidoodle3.ini (3.1 KB)
June 05, 2014 03:15AM
I found cura prints small gears perfectly.
June 05, 2014 07:01AM
Thanks
I tried cura and am getting the same results. Can you post your setting file?
June 05, 2014 07:36AM
what is your fill density (cura) - Infill(slic3r) set at? try 100% fill and see if that helps.
June 05, 2014 05:45PM
Setting infill to 100% doesnt help. With Cura, nothing, with Slic3r it causes the shaft hole to be messed up. There must be someone who can print these because my printer came with one! My gear is cracked and need to print one before it gives out.
June 05, 2014 06:27PM
Sorry the screen on my laptop has died so can't copy my settings for cura over at the moment. What are your overlap settings in cura? I found the default was too high so reduced it to 5% although I have used 3% without a problem. I found slicing it with cura and then viewing the code in repertier host a real help with working out shell thickness etc.
June 05, 2014 06:36PM
Have you tried concentric infill with slic3r? Or setting the perimeters really high so it basically does the same as concentric infill. Wish I had it open in front of me. Must fix laptop.
June 06, 2014 12:08AM
No I didnt try concentric infill at 100% yet but will, my last one was using rectilinear. I will try it.
