j head jam June 11, 2014 05:56AM |
Re: j head jam June 11, 2014 11:11AM |
Re: j head jam June 11, 2014 01:22PM |
So I have bought a bad hot-end, my fail.Quote
pokey9000
Read this post about J-Head clones.
A few things are probably going on here:
-A badly designed or manufactured nozzle is more likely to build up back pressure, especially with PLA. It's also possible that manufacturing debris or PEEK from your attempts to recover from the meltdown could be causing the clog too.
-The heat break with 4 vent holes is less effective at keeping the incoming PLA cool, leading to possible jams. From the looks of it, your hotend mount blocks the upper 1 1/2 vents. Although not ideal, as long as the fan was running I doubt these are the culprit.
-Even with a clone, the barrel is still PEEK and should survive to ~245C. This shouldn't happen at 165C (which is low for most
PLA). One of the following could have caused the meltdown: wrong thermistor setting in firmware, bad thermistor connection, thermistor isn't thermally coupled to the block enough. If possible, get a thermometer you can jam down the barrel to insure that it's hitting the temps that you're dialing in.
-Not sure how you managed to fix the melted threads... but if you had to shorten the barrel in the process, you need to trim the PTFE to match and make sure not to overtighten the set screw.
I wouldn't spend any more time on this hotend, especially with an E3D on the way.
Re: j head jam June 11, 2014 08:11PM |
EEstudent
I've ordered E3D-V5 full kit just to avoid the problems I faced. should it be good for PLA? ,some people claim it is not good for PLA and jams a lot.
Re: j head jam June 12, 2014 06:20AM |
I am glad to hear that.Quote
vreihen
EEstudent
Mine has been through almost a full spool of PLA without a jam on an E3D-v5/Bowden setup. As long as the fan is running 100% at all times, I suspect that you will not have any problems either.....
