Struggle with PLA June 21, 2014 09:59PM |
Re: Struggle with PLA June 21, 2014 10:33PM |
Re: Struggle with PLA June 22, 2014 09:05AM |
Re: Struggle with PLA June 22, 2014 09:14AM |
Re: Struggle with PLA June 22, 2014 07:21PM |
Re: Struggle with PLA June 22, 2014 10:32PM |
MrBaz
I get jams even when I am manually pushing filament through. At first, I am easily able to push filament through, then it just gets hard and harder to push filament through until it completely jams.
Re: Struggle with PLA June 27, 2014 09:34PM |
A2
MrBaz
I find this quote perplexing. Because you can push the filament through at a high rate, enough so that heat doesn't migrate up the filament to cause a "plug" jam.
I think you should go on the Google forum, and pick their brains.
Possibly your thermistor is not potted or wiggling in the well, making intermittent contact, and temps are higher than you think. ABS can take a higher temp, temps that will cause PLA to collapse. Try potting the end of the thermistor with high temp silicone in the well.
You should take some pictures of your rig too.
Review the following parameters against your settings:
RepRap: Printing Parameters Database
[reprap.org]
PLA, (Polylactic acid, or polylactide, Type: extruded):
Drying Temperature:
Range: 45°C to 100°C, (113ºF to 212ºF)
Dry time:
Range: 4 hours.
Glass-transition temp:
Range: 45°C to 120°C, (113ºF to 248ºF).
Average: 59.6°C, (139ºF).
Wikipedia: 60°C to 65°C, (140ºF to 149ºF).
Begin testing around this temp:
Substrate/bed temperature: 60°C, (140ºF).
Enclosure temperature: 60°C, (140ºF).
Machine parameters:
Extrude temp (RepRap): 165°C ~ 200°C.
Wikipedia: melting temperature between 173-178 °C
Re: Struggle with PLA July 01, 2014 08:18PM |
Re: Struggle with PLA July 01, 2014 09:39PM |
Dear Natalie,
Permanent inks, like the classic Sharpie, contain three main ingredients: colorant, carrier (solvent) and resin (polymer). For permanence, the colorant of choice is pigments (as opposed to dyes). Pigments do not fade like dyes and do not bleed through paper. Solvents for the old markers (up until the 1990's) were nasty-smelling organic chemicals such as xylene. Nowadays, the solvent of choice is an alcohol (ethanol or isopropanol), which is more enviromentally friendly and better smelling, while still evaporating quickly to prevent messy smearing, etc. Finally, there is a resin or polymer that is added as a "binder" that promotes adhesion... A permanent resin is not permanent unless it sticks like glue to most of the surfaces it is written on. The resin forms a film (once the alcohol evaporates) that allows the ink to write smoothly and uniformly on any surface (smooth or rough) while acting like glue for the pigment. Resins come in all shapes and sizes, typically, urethane acrylic resins are used (like those used in house paints).
I Hope this is helpful.
Sincerely,
Keith Allison ("Dr. Crayola")
Senior Chemist
Binney & Smith, Inc.
[www.madsci.org]
Re: Struggle with PLA July 01, 2014 10:00PM |
Re: Struggle with PLA July 02, 2014 09:17PM |
A2
A very interesting development. Possibly you have coated the PLA with a resin that performs as a lubricant. What color, mfg, and amount of surface area did you coat the natural PLA?
Dear Natalie,
Sincerely,
Senior Chemist
[www.madsci.org]
