Printing small objects with a bowden extruder June 25, 2014 09:28PM |
Re: Printing small objects with a bowden extruder June 26, 2014 04:01AM |
Re: Printing small objects with a bowden extruder June 26, 2014 04:48AM |
Re: Printing small objects with a bowden extruder June 26, 2014 08:14AM |
Re: Printing small objects with a bowden extruder June 26, 2014 10:20AM |
Srek
What kind of nozzle are you using? The best bridges and overhangs can be printed by using a very pointed nozzle. Flat tipped nozzles make it easy to create smooth surfaces, but they will not be able to make really good bridges.
Re: Printing small objects with a bowden extruder June 26, 2014 10:35AM |
Re: Printing small objects with a bowden extruder June 26, 2014 11:28AM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Printing small objects with a bowden extruder June 26, 2014 02:55PM |
Sublime
I would say your prints are almost perfect except for heat.
Didn't know that, always treated them the same, thank you for that revelation.Quote
Sublime
Also an overhang has nothing to do with bridging, they are seen as completely different things by the slicing software.
Re: Printing small objects with a bowden extruder June 26, 2014 03:10PM |
DinoK
Sublime
I also like JerseyGirl's print over my own. I tried 3 prints and still haven't perfected the settings.
Sublime
Must also compliment your calculator, it made a huge improvement in quality of my prints. Only wish there would be an offline version available.
Re: Printing small objects with a bowden extruder June 26, 2014 03:13PM |
Re: Printing small objects with a bowden extruder June 26, 2014 03:16PM |
DinoK
Sublime
Sublime
Re: Printing small objects with a bowden extruder June 26, 2014 03:19PM |
Re: Printing small objects with a bowden extruder June 26, 2014 07:36PM |
Re: Printing small objects with a bowden extruder June 27, 2014 02:29AM |
Re: Printing small objects with a bowden extruder June 27, 2014 01:27PM |
DinoK
I just solved my 'curly hair' problem. As my friend ,the computer programmer, likes to say : It's a feature, not a bug
Was looking at gcode and discovered that the path is wrong (like one way street sticking out) at the exact spots where my curls appear:
JerseyGirl would you mind sharing your gcode ?
Re: Printing small objects with a bowden extruder June 27, 2014 07:19PM |
Re: Printing small objects with a bowden extruder June 27, 2014 07:27PM |
JerseyGirl
I found a sample of PLA I had from Faberdashery and no luck again making a perfect part. I'm ordering a smaller nozzle. Maybe 0.5 is too much for this size.
Re: Printing small objects with a bowden extruder June 28, 2014 05:59PM |
I turn two 40mm fans on after the first layer is laid down. I had the exact same problem. I couldn't build the heart gears until I added cooling. The print bed stays hot enough to keep the part down even when cooling. Commercial printers have ridiculous amounts of cooling inside. Its their little secret.
How "dry" is it when the next layer goes down? ..... if there is any wiggle or "jello" to the last layer when
the new one is going down, you are going to have this problem. The tension of the extruder moving away from the corner I SUSPECT
pulls up the corner, so the softer it is, the bigger the problem.
Re: Printing small objects with a bowden extruder June 29, 2014 08:41AM |
Re: Printing small objects with a bowden extruder June 29, 2014 11:20AM |
Re: Printing small objects with a bowden extruder October 02, 2014 03:13PM |
Re: Printing small objects with a bowden extruder October 03, 2014 05:06PM |
LoboCNC
I'm a bit late to the game on this thread, but I've been experimenting lately with different nozzle tip tapers, flat sizes and cooling. It seems the problem with a large flat is that is simply pumps too much heat into the surrounding material as it lays down each line. Same with a flatter tip taper - it radiates more heat down into the existing material. My latest iteration has a total cone angle of about 80 deg. (pretty similar you your Airwolf nozzle) but a flat on the tip of about 1mm dia. I noticed that your Airwolf nozzle has two black-oxide cap screws that ride just above the print surface - these are going to radiate a lot of extra heat into the material as well.
Cooling is also crucial. I started off with a ducted fan, but after looking at a Makerbot Replicator, I switched to a ducted blower (an actual blower rather than a blower-fan) which can produce a much higher velocity airflow. It nearly whistles as it moves across the print.
My test print has been a single, hollow 12mm ball with no supports, raft or brim. Any curling of the overhang will cause the print to dislodge, which makes for a pretty good acid test. It's also easy to measure the final print to look for irregularities - particularly in the steep overhang on the lower part of the ball.
