Brittle PLA prints
Posted by Capinho
Brittle PLA prints
July 08, 2014 02:36AM
Hello everyone.
Since my extruder/hotend jammed, I took it apart and after reassembling it, my prints became very brittle. I did not change anything except stepper voltage (from 0.425 to 0.55). I also recalibrated my steps/mm. And now, my prints are fragile, "hairy", not shiny and brittle. Could it be my thermistor issue (isolation or broke) caused while reassembling? However, my temperature reading seems to be fine ( it reads the temp it should). I have tried using different plastic, same thing. I am printing at 190 degrees, however, I tried to change it up to 220, same thing happens.
Here are few photos:
[fbcdn-sphotos-h-a.akamaihd.net]
Anonymous User
Re: Brittle PLA prints
July 08, 2014 04:39PM
It looks like you're under-extruding from the photo. Steps/mm should not change unless you change the gearing on your extruder. Have you tried reverting to the original value?
July 09, 2014 01:42AM
While reassembling the extruder, I retightened every single bolt and screw, so the forces pressing fillament have changed, so as a result, my steps/mm changed. Without recalibrated steps/mm, I got like 5mm off. Under extruding, by that you mean my feed rate is too low? If so, even when I turn my extruder gear by hand, the fillament coming out is grey, instead of black, and it looks not the same, as it looked before.
Anonymous User
July 10, 2014 05:31PM
What extruder / hot end are you using? Increasing the force on the filament should not have changed the steps per mm, unless your extruder was slipping prior to the recalibration.
July 11, 2014 06:04AM
3dkarma
I am using RepRap 3drag printer with the hotend/extruder it comes with.
Reuploaded pic
Edited 1 time(s). Last edit at 07/11/2014 07:17AM by Capinho.
July 11, 2014 03:55PM
Definitely uneven extrusion. Possibly wrong steps/mm
What is your print speed?
Get an IR/laser temp gauge.
July 12, 2014 08:04PM
MrBaz
My print speed is 50 mm/s
