Disregarding triggered end stop during print July 27, 2014 05:42PM |
Re: Disregarding triggered end stop during print July 28, 2014 11:06AM |
Re: Disregarding triggered end stop during print July 28, 2014 03:14PM |
Re: Disregarding triggered end stop during print July 28, 2014 06:46PM |
Re: Disregarding triggered end stop during print July 29, 2014 09:11AM |
flycouch
Hey,
I also bought a i3 from the Czar and I am having the exact same problem.
Homing seems to work, then when printing, it's, "Dive Captain Dive", right into the bed.
Z endstop set at minimum position.
Everything else seems pretty cool and 3dprinterczar.com replaced some parts broken in transit straight away.
peace,
flyCouch
Han
Usually after calibrating the printer, we will disconnect first, then connect and print. One possibility for your problem might be that you skip the disconnecting part. However, we don't use the z axis endstop very often, so we forward your question to our engineer for further discussion.
If you have any additional questions that we can help, please don't hesitate to ask.
Best,
Han
3D Printer Czar
Re: Disregarding triggered end stop during print July 29, 2014 01:09PM |
Re: Disregarding triggered end stop during print July 30, 2014 02:58PM |
Re: Disregarding triggered end stop during print August 04, 2014 01:53PM |
brucehvn
It almost sounds like there's a z offset set in EEPROM, which is usually used for auto bed levelling. I take it these printers don't come with a z probe for ABL, right? Is auto bed levelling enabled in your Configuration.h?
If not, then maybe try and reset the EEPROM to clear out any bad settings. Manually run an M502 command to restore to the settings in the Configuration.h. Then run M500 to store the settings back to EEPROM.
Re: Disregarding triggered end stop during print August 16, 2014 11:22AM |
Re: Disregarding triggered end stop during print August 16, 2014 01:17PM |
Re: Disregarding triggered end stop during print August 16, 2014 05:16PM |
Re: Disregarding triggered end stop during print August 16, 2014 05:59PM |
Re: Disregarding triggered end stop during print August 20, 2014 08:32AM |
