Extruder jam ?
Posted by Walther
Extruder jam ?
July 29, 2014 11:14AM
I think the attached video show an extruder jam ?
[www.youtube.com]
The stepper motor started ticking over during a print, and I tried to start print again which is on the video (and quickly turned it off).
I have just purchased the machine and is starting to learn about 3D printing, but the only thing I know is that it is a MendelMax1.5, but is not enough to do a detailed search on the extruder.
I use 3mm PLA, that is from the end of a roll, so it is very curved.
Should I increase extrusion temperature, currently at 185 degrees ?
I have made a successful print:
Re: Extruder jam ?
July 31, 2014 10:46AM
So I just got some new filament from Faberdashy.
What I have found is that when the print goes fast (long stretches of infill), the little herring wheel on the E motor starts moving out of the larger wheel, until it finally starts ticking over.
I can help it a little if I manually help turn the larger wheel.
Is my temperature too low, or ?
Thank you,
Re: Extruder jam ?
July 31, 2014 11:10AM
Tried raising the temperature from 185 to 195,... did not really help.
Re: Extruder jam ?
July 31, 2014 12:45PM
Just took the extruder apart.
One of the bearings was jammed, and the main axis could hardly turn.
Not related to printing, sorry.
Thank you,
