This is a new one... Pock marks August 01, 2014 05:22PM |
Re: This is a new one... Pock marks August 01, 2014 09:01PM |
Re: This is a new one... Pock marks August 01, 2014 09:33PM |
Re: This is a new one... Pock marks August 01, 2014 09:40PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: This is a new one... Pock marks August 01, 2014 09:46PM |
Re: This is a new one... Pock marks August 01, 2014 09:47PM |
Re: This is a new one... Pock marks August 01, 2014 09:59PM |
Re: This is a new one... Pock marks August 01, 2014 10:42PM |
Re: This is a new one... Pock marks August 01, 2014 10:55PM |
Re: This is a new one... Pock marks August 02, 2014 02:04AM |
tmorris9
By the way I am a logical thinker and I like to understand why something needs to be set the way it is rather than someone just saying set it at this with no explanation. Sublime you showed me with the calculation something I had not considered before (layer height x layer numbers = thickness) it seems so simple now and I feel a little stupid for not thinking of it that way. So thank you.
Re: This is a new one... Pock marks August 06, 2014 11:24AM |
I wouldn't say "perfect". It seems like the text came out much nicer in your s3d print. Higher infill + more top layers, as I'm sure you've already gathered...Quote
tmorris9
So I remade it using Slic3r and the results are perfect... Hope I didn't waste $140 on Simplify3D, it's suppose to be way better than Slic3r.
Re: This is a new one... Pock marks August 06, 2014 03:01PM |
isonoob
tmorris9
Re: This is a new one... Pock marks August 06, 2014 08:35PM |
tmorris9
The text problem was actually a failure in the file, it had errors that even netfabb basic could not fix. I guess Simplify3D was more forgiving in that respect.
Re: This is a new one... Pock marks August 06, 2014 11:46PM |
Re: This is a new one... Pock marks August 06, 2014 11:52PM |
MrDoctorDIV
Just throwing out my potentially useless thought:
You were using the same temp on both, correct? I've noticed in my limited tests that ABS will parse like that along bridging areas when temp is too low.
Re: This is a new one... Pock marks August 07, 2014 12:04AM |
Re: This is a new one... Pock marks August 07, 2014 12:38AM |
Re: This is a new one... Pock marks August 07, 2014 01:04AM |
Re: This is a new one... Pock marks August 07, 2014 01:06AM |
Re: This is a new one... Pock marks August 07, 2014 04:44AM |
Re: This is a new one... Pock marks August 07, 2014 09:28AM |
Re: This is a new one... Pock marks August 07, 2014 09:40AM |
