Hotend temperature shoots up to max August 12, 2014 11:00AM |
Re: Hotend temperature shoots up to max August 12, 2014 11:33AM |
Re: Hotend temperature shoots up to max August 12, 2014 12:11PM |
Thanks for your quick reply. Thankfully, only setpoint was set to 400 degrees, the printer shut down at 300, so my thermistor is still alive. I will try doing new PID autotune tomorrow, when i get back to work and hopefully, that will fix this problem.Quote
MrDoctorDIV
Ouch, that's a game that will always be lost. PID needs to be run for every major temp change. The difference between 230C and 260C requires a new PID tuning in my experience. Having jumped to 400C your thermistor is dead I'm sure. You'll have to get a new one. I got my v6 and PID'd at 200C at 8 cycles. I wouldn't print until you get a new thermistor, reporting the wrong temps is a fire hazard.
Re: Hotend temperature shoots up to max August 13, 2014 01:26AM |
