Consistant Layer Shift
Posted by remmec
August 13, 2014 08:52PM
I get a layer shifts in the same locations on all my prints and I don't know whats causing them.
Any ideas?
Edited 1 time(s). Last edit at 08/13/2014 08:54PM by remmec.
Re: Consistant Layer Shift
August 14, 2014 06:45PM
shift? as in, to one side? or is the ridge all the way around? Because the first could be an irregularity in your threaded rods. Are they actually straight?
August 14, 2014 08:01PM
A rod irregularity wouldn't make such a sharp change.
What kind of threaded rod [if that's what you have] are you using? Do you know the exact pitch? Are your Z-steps set correctly?
Realizer- One who realizes dreams by making them a reality either by possibility or by completion. Also creating or renewing hopes of dreams.
"keep in mind, even the best printer can not print with the best filament if the user is the problem." -Ohmarinus
