Annoying Start Gcode - Clogging Hotend September 02, 2014 02:57AM |
G1 F500 E35 ; 500mm/min speed of print head, 35mm filament to extrude
Re: Annoying Start Gcode - Clogging Hotend September 02, 2014 09:55AM |
Re: Annoying Start Gcode - Clogging Hotend September 02, 2014 01:29PM |
Re: Annoying Start Gcode - Clogging Hotend September 02, 2014 06:14PM |
; generated by Slic3r 1.1.7 on 2014-09-02 at 14:49:57 ; perimeters extrusion width = 0.40mm ; infill extrusion width = 0.42mm ; solid infill extrusion width = 0.42mm ; top infill extrusion width = 0.42mm G21 ; set units to millimeters M190 S110 ; wait for bed temperature to be reached G28 ; home all axes M109 S215 ; heat up hot end to set temperature M82 ; use absolute distances for extrusion G90 ; use absolute coordinates G92 E0 ; set E value to 0 at current position G1 F500 E35 ; 500mm/min speed of print head, 35mm filament to extrude G92 E0 ; set E value to 0 at current position G90 ; use absolute coordinates G92 E0 M82 ; use absolute distances for extrusion G1 F1800.000 E-1.00000
Re: Annoying Start Gcode - Clogging Hotend September 02, 2014 08:48PM |
