Undersized circles - Has this been solved yet? September 14, 2014 01:04PM |
Re: Undersized circles - Has this been solved yet? September 14, 2014 02:13PM |
Re: Undersized circles - Has this been solved yet? September 14, 2014 02:46PM |
Re: Undersized circles - Has this been solved yet? September 14, 2014 11:28PM |
Re: Undersized circles - Has this been solved yet? September 16, 2014 01:22AM |
Re: Undersized circles - Has this been solved yet? September 18, 2014 12:39PM |
Re: Undersized circles - Has this been solved yet? September 21, 2014 05:21PM |
Re: Undersized circles - Has this been solved yet? September 22, 2014 03:34PM |
Re: Undersized circles - Has this been solved yet? September 22, 2014 06:21PM |
DinoK
@redhatman Can you please give some STL or(and) GCode examples of your failed prints ?
I would like to try and print them myself as I have been researching this issue myself.
Re: Undersized circles - Has this been solved yet? October 05, 2014 09:06PM |
Re: Undersized circles - Has this been solved yet? October 05, 2014 09:11PM |
Re: Undersized circles - Has this been solved yet? February 22, 2015 11:52AM |
DinoK
I wrote more detailed article about it on the blog.
To sum it up, everybody can do it, you just have to fine tune the printer
Re: Undersized circles - Has this been solved yet? February 22, 2015 05:40PM |
pistolero
DinoK
I've read your post dozens of times, but still don't understand what to do to make my Kossel print holes with exact internal diameters.
I'm printing with PLA now, 200C, 60mm/s. Shell thickness is a double of nozzle diameter (2*0.4mm=0.8mm) and layer height is 0.2mm.
I've tried bigger shell thickness and 0.1mm layers and other temperatures, but regardless of the settings my holes (either round or square) are printed smaller than needed by ~0.5mm.
This is blocker for me. I'm trying to print engineering parts and precise dimensions are required for assembly.
Any help how to teach my Kossel mini to print holes with exact diameters would be appreciated .
Re: Undersized circles - Has this been solved yet? February 22, 2015 05:43PM |
Re: Undersized circles - Has this been solved yet? February 23, 2015 09:15PM |
Re: Undersized circles - Has this been solved yet? January 11, 2016 02:09AM |
Re: Undersized circles - Has this been solved yet? January 11, 2016 02:28AM |
Re: Undersized circles - Has this been solved yet? July 04, 2016 07:45AM |
Re: Undersized circles - Has this been solved yet? July 04, 2016 09:03PM |
Re: Undersized circles - Has this been solved yet? July 05, 2016 10:03PM |
Re: Undersized circles - Has this been solved yet? July 06, 2016 03:07AM |
PDBeal
Wouldn't the width be different depending on how much filament is hanging from your hotend, as it gets longer, I'd imagine gravity will pull it down more so than if it was fresh out of the nozzle. I've also seen right as it starts to extruder in mid air it begins to overlap itself at first and then finally begin to fall slowly which in turn would also affect the width of the extruded filament.
I wonder if it wouldn't be better to have a given gcode string to extrude a known line on the bed and measure that rather than extruding in mid air.
Re: Undersized circles - Has this been solved yet? July 29, 2016 10:44AM |
Re: Undersized circles - Has this been solved yet? January 08, 2017 01:23PM |
Re: Undersized circles - Has this been solved yet? January 08, 2017 01:31PM |
Re: Undersized circles - Has this been solved yet? January 08, 2017 03:49PM |
Re: Undersized circles - Has this been solved yet? January 10, 2017 10:32AM |
Re: Undersized circles - Has this been solved yet? January 10, 2017 11:59AM |
Re: Undersized circles - Has this been solved yet? January 10, 2017 01:43PM |
Re: Undersized circles - Has this been solved yet? January 10, 2017 04:24PM |
Farnomat
I don't know if somebody already suggested this, but if the holes are constantly too small (for example always .5mm), there's a setting called "Dimensional Accuracy" or "horizontal size compensation" or smth. like that in most of the slicers. If your holes are always .5mm too small, try typing in -0.25mm (so just half of the amount that they are too small) If your holes are too big then do the same but with positive values.
Re: Undersized circles - Has this been solved yet? January 10, 2017 05:51PM |
