Everything is too tight. September 28, 2014 12:33PM |
Re: Everything is too tight. September 28, 2014 06:33PM |
Re: Everything is too tight. September 29, 2014 03:15AM |
Re: Everything is too tight. September 29, 2014 04:14AM |
Re: Everything is too tight. September 29, 2014 04:22AM |
tmorris9
This is a well known attribute of FDM printing. It has to do with 2 main things 1. plastic shrinking inward and that circles are made from straight lines so they "cut corners",
The only cure right now is to print a size chart and calculate hole size based on that or estimate about 1mm extra on holes. Here is the hole chart I developed, it's thin so does not take up much material yet the holes are 1mm increments unlike others that can be 5mm increments [www.thingiverse.com]
Re: Everything is too tight. September 29, 2014 10:28PM |
Re: Everything is too tight. September 30, 2014 02:58AM |
Re: Everything is too tight. September 30, 2014 05:02PM |
