PLA doesn't stick to hotbed
Posted by barakori
October 11, 2014 12:40PM
I've printed ABS in the past (with mixed to good results, really depending on the model), and now I decided to try to print using PLA.
I cleaned the head, ran 50 mm of PLA through it and checked that X, Y, Z and E are calibrated.
As a first print, I tried a 25 mm cube, and at z = 2.25 mm, the cube just detached from the heated bed. The result bottom part was also wrapped at the bottom (a slight curved surface).
I switched to PLA assuming it deforms less and easier to stick, but so far, no luck here :-(
The first print was done with temp = 80 on glass.
I tried a second time with temp = 80 and hairspray (the same one I successfully used for ABS), and the results were the same, now at 2.5 mm...
Here's a picture, but it doesn't say a lot, the printed part just unstuck from the hot bed and rotated:
Any tips on this? Is there a way not to use blue tape? Not sure I can get one in my country (or how it's called locally).
Thanks.
Re: PLA doesn't stick to hotbed
October 11, 2014 02:19PM
What is the nozzle height for the first layer? It should really be smooshed down, I use a business card to measure the height. If painters tape is unavailable, Elmer's glue work quite well. ABS should really be printed on at least 100C plate for it not to warp.
[scara3dprinter.wordpress.com]
October 11, 2014 03:00PM
Thanks for the reply.
I'm adjusting the nozzle height to be very close to the bed - the height of normal paper, which is less than a business card.
For ABS I used 110C, but for PLA it's 80C - I'm using the default configuration that was provided by the company who sold me the kit (makerfarm).
Note that it seemed like the first layer stuck really well. The second layer printed fine, third also, etc. Only at around the 10th layer (I'm printing at h=0.25mm and w=0.35mm), the base of the cube, which looked glued to the build plate, started moving, and then I knew it's lost...
Any suggestions?
October 11, 2014 05:23PM
So its probably not bed temperature related unless for some reason the bed is turning itself off during the print. If you are still printing in ABS another solution would be to take some acetone, disolve some ABS filament in it to the point where it is a milky consistency, then use a small paintbrush to apply a thin coat. If the coating is too thick, you'll never get your print off the glass smiling smiley
Edited 1 time(s). Last edit at 10/11/2014 05:23PM by Evil Monkey.
October 11, 2014 05:39PM
80C is too high a bed temperature for PLA. Try 55 to 65C.
October 12, 2014 11:55AM
The outer perimeter looks weird, what temperature you set for PLA ? Layer delamination indicates low temperature.
Check your extrusion rate, your temperature and first layer hight. Use purple Elmer glue and use as maximum 70 for the bed temperature.
October 12, 2014 11:59AM
The dotted outer skirt shows that either you are too far of the built plate or you are extruding too little or too cold.
October 14, 2014 03:22PM
I use plain 2mm thick glass on my heated bed. For PLA I set the bed temperature to 70C which gives ~55C on the glass surface.
I clean the glass with Pure White Vinegar (95% pure water and 5% Acetic acid) which you can buy from any supermarket in the cooking aisle. I use cheap tissues and rub until the glass squeaks.
You must adjust your first layer height accurately. If you are printing with a layer height of 0.2mm then measure the skirt thickness and adjust your Z height to give exactly 0.2mm.
When I print PLA I use an extruder temperature between 185C and 205C for print speeds of 40mm/s to 80mm/s (5C temperature increase for each 10mm/s speed increase) and turn the carriage-mounted fan on fully after the first layer.
You must let your heated bed cool fully after which a moderate twisting action will release your print.
Regards,
Neil Darlow
I try to write with consideration for all nationalities. Please let me know if something is unclear.
Printing with Mendel90 from fedora 25 using Cura, FreeCAD, MeshLab, OpenSCAD, Skeinforge and Slic3r tools.
October 15, 2014 08:15AM
Use hairspray or a gluestick (pritt, uhu, etc what the kids use in school) on your glasstop.
No need for squeeky clean surfaces or worrying that the print will stick forever to the glass.
I print 4 - 5 prints like this, wash the glass with soap and water, re-apply and print.
October 16, 2014 03:24PM
Thanks for all the responses.
To sum up, I tried printing with the hotbed at 60C and it sticks great. Don't have any sticking / wrapping issue at this point.
The outer rim is "dotted" because initially, I think there's not enough material in the hotend chamber. While I wait for the hotend to reach 195C, a lot of filament is dropped, so by the time I start printing, there needs to be some extra pushing of material. Maybe 195C is too high for my PLA, but that's probably for another thread.
Again, thanks for all the responses.
October 17, 2014 08:43AM
did you try to use a PEI plate instead of glass?
I tried one for printing with PLA and had good results. You need to have head bed > 60° to get a good adhesive.
As soon as printing is finished and the head bead has cooled down, the print can be easily solved from the PEI plate.
BR
Peter
RepRap Electronics, Mechanics, NEMA 17, Filament you find here: [www.my-home-fab.de]
