Upper flange collapsing
October 26, 2014 02:38PM
So this is my 20 tooth GT2 belt pulley.
The flange are 1.5mm thick.
As you can see, the lower flange with support prints fine, however the upper flange fails to materialize.
Any suggestions?
I'm running at 195 degrees using 3mm filament.
[bad photo #1]
[bad photo #2]
*** EDIT ***
So, it took mere minutes for me to stop being lazy and read some past posts.
Several parameters were suggested by others with similiar problems.
I'll check a few settings before I continue this thread.
Edited 1 time(s). Last edit at 10/26/2014 02:43PM by Titanium69.
open | download - IMG_2772.JPG (483.5 KB)
open | download - FILE0006.JPG (420.3 KB)
Re: Upper flange collapsing
October 26, 2014 04:57PM
A cooling fan aimed at the part and print 2 at once.
_______________________________________
Waitaki 3D Printer
October 26, 2014 09:33PM
You need support to print that upper flange.
