Look My Test Print Gears And Help To Improve Quality
Posted by Plasteroid
October 27, 2014 01:47PM
Should I lower acceleration, speed or what? 230C Hotend & 110C Bed. The hollow calibration cube prints more nicely compared to these gears.
Prusa i3, Ramps 1.4. Catnozzle 0.4mm
SketchUp - Enveloping Globoid Worm Gear - Part One - 3D Printed: [youtu.be]
DesignSpark Mechanical & more precise screw thread: [youtu.be]
Nicer Screw Thread In SketchUp ( Bolts,Nuts): [youtu.be]
How To Model A Heart Shape In SketchUp: [youtu.be]
How To Draw 3D Printable Snap Fit Ball Joint In SketchUp: [youtu.be]
open | download - gear02layer.jpg (98.7 KB)
open | download - gear035layer.jpg (126.7 KB)
Re: Look My Test Print Gears And Help To Improve Quality
October 27, 2014 04:23PM
3 things:
Temperature
Infill to perimeter overlap
Extrusion width
October 27, 2014 04:26PM
If you want to keep the temperature then for small parts you need to delay some more the time to start the next layer.
October 28, 2014 06:34AM
Further to what ggherbaz said, print 4 at the same time will achieve this. Each small gear will cool sufficiently while the hotend is off doing the other ones.
October 28, 2014 09:08AM
230 Is too hot for such a small part. Try 220 and print at least two of them.
October 28, 2014 12:00PM
Thank yoy very much! I managed to improve quality very much, almost perfect (gear9better.jpg). Perhaps I could have done something better, but this was good enough. I see a little design flaw on my first gear drawing.
I lowered temperature to 225. I did not try to print 4 at once, yet, but here are the other setting that I made in Slic3r:
Avoid crossing perimeters true.
; generated by Slic3r 1.0.0RC2 on 2014-10-28 at 15:48:09
; layer_height = 0.25
; perimeters = 3
; top_solid_layers = 3
; bottom_solid_layers = 3
; fill_density = 0.4
; perimeter_speed = 30
; infill_speed = 40
; travel_speed = 130
; nozzle_diameter = 0.4
; filament_diameter = 3
; extrusion_multiplier = 1
; perimeters extrusion width = 0.40mm
; infill extrusion width = 0.40mm
; solid infill extrusion width = 0.40mm
; top infill extrusion width = 0.40mm
; first layer extrusion width = 0.40mm
open | download - gear9better.jpg (112.5 KB)
October 28, 2014 01:54PM
Good print. Lower your extrusion multiplier to 0.9 on small parts like that one.
