Any idea on what's happening here ?
November 07, 2014 01:53PM
The second layer is not properly adhering to the bottom layer, and is pulled back with the nozzle.
This happen at all heights, but usually only for pointy edges. It was just very clear in this print.
Printed with PET T-Glase, 15mm/s, 190C, 0.5mm nozzle, 0.4mm layer, bed 60C ?
Thank you,
Edited 1 time(s). Last edit at 11/07/2014 01:57PM by Walther.
Re: Any idea on what's happening here ?
November 07, 2014 03:37PM
Might try bumping the heat a bit, I thought that stuff liked it more towards 212c?
November 07, 2014 04:53PM
Wow, wrong temperatures for t-glase (230~240 for hot end and 80~90 bed) and lower layer height to 0.3 , the speed is fine though.
November 10, 2014 01:38PM
Thank you for the replies,
It helped raising the temperature.
The reason I had it low, was because I had a lot of oozing when initially heating the printer.
It would drain the nozzle, and I had to compensate with a lot of skirt/brim.
Thanks,
November 10, 2014 03:53PM
ciao a tutti , sono appena arrivato , uso una prusa mendel i3 . non riesco a capire il problema di questo cubo (^^ foto). abs 230-90 .gra
open | download - 2014-11-10 21.51.11.jpg (351.5 KB)
November 10, 2014 04:06PM
all 'interno รจ vuoto
November 11, 2014 07:35AM
scusi, no parlo Italiano.
You have several issues, from loose belts to over extrusion, you might be trying to print too fast.
I'll be better if you find someone that can parlare italiano with you and go through all the problems you have.
Ci vediamo
November 12, 2014 03:07PM
grazie moody smiley
November 15, 2014 08:31AM
Yes at 190, it's amazing it worked at all.
