Shifting layers November 10, 2014 06:50AM |
Re: Shifting layers November 10, 2014 07:53AM |
Re: Shifting layers November 10, 2014 09:09AM |
Re: Shifting layers November 10, 2014 09:01PM |
Re: Shifting layers November 11, 2014 02:26AM |
yes, and most likely the latter. If your steps per mm were off, the effects would be linear, not random. Check for loose belts, binding, etc.Quote
ggherbaz
Then either your steps per mm are wrong for the failing axis or you have a loose belt or pulley
Re: Shifting layers November 12, 2014 05:17AM |
