Wipe extruder tip in a box - GCode ? November 12, 2014 04:30AM |
Re: Wipe extruder tip in a box - GCode ? November 12, 2014 10:11AM |
Re: Wipe extruder tip in a box - GCode ? November 12, 2014 11:55AM |
Re: Wipe extruder tip in a box - GCode ? November 12, 2014 12:42PM |
Re: Wipe extruder tip in a box - GCode ? November 13, 2014 03:07AM |
Re: Wipe extruder tip in a box - GCode ? November 13, 2014 11:14AM |
*** tool-change GCode start here*** G60 ; Memory position G92 E0; reset extruder position G1 E-15 F1000; retract filament of the actual extruder to prevent ooze G1 Z50 F300; raise z to the correct height for wipe against the wiping wires but not crash the waste filament's box G1 X200 Y200 F6000; go over the center of the box T[next extruder]; select the extruder that will print after the "macro" execution G92 E0; G1 E20 F1000; extrude more filament than the amount retracted on the previous tool-change G1 E-1; small retract, as default for layer change G90; G61 Z1 F6000 G61 X Y F6000 G61 Z F6000 *** tool-change GCode stop here***
Re: Wipe extruder tip in a box - GCode ? November 13, 2014 11:21AM |
Re: Wipe extruder tip in a box - GCode ? November 13, 2014 02:10PM |
Re: Wipe extruder tip in a box - GCode ? November 14, 2014 12:31PM |
Re: Wipe extruder tip in a box - GCode ? November 18, 2014 03:00PM |
