ABS problems: delamination, cracks, warping [SOLVED]
Posted by abuharsky
November 19, 2014 05:54AM
Hello All.
I spent a couple of weeks, even months in a vain attempt to print anything from ABS plastic.
There are no problems with printing small models, but with large models having constant problems: you just can not print any big vase without cracks and delaminations!
First, I tried few experiments with slicer(KISSlicer) settings for better adhesion between layers (slightly more flow rate, slightly more hotend temp - 240C, 250C instead of 230C, very low speed - 20-30 mm/s).
Second, I tried to make simple enclosure for printer using cardboard.
Third, I tried to print model inside thin wall to make thermos effect to get uniform cooling of the plastic.
although it did not work out all the details of cracked angry smiley
I wanted to understand why this is happening.
At high temperatures, the plastic expands when low narrows, it creates internal tension. It is necessary to calculate or determine experimentally the value of narrowing:
1) look for the coefficient of thermal expansion ABS: 73.8 * 10 ^ -6 ° C-1 ( [temperatures.ru] )
2) remember physics 6th grade smiling smiley ( [goo.gl] )
3) calculate how much less will be the length of the extruded rod 100mm at the bed temperature of 100C and 230C of the nozzle
ΔL = a * L * Δt = 73.8 * 10 ^ -6 * 100mm * (230C - 100C) = 0,96mm - which is almost 1% of the original length.
Upon reaching room temperature, 25 ° C - it is 1,5% (ΔL = a * L * Δt = 73.8 * 10 ^ -6 * 100mm * (230C - 25C) = 1,51mm)
1% - It is very small.
Accordingly, with this small change in length of the plastic (1%) occurs corresponding to the internal pressure value of which is not too high.
The fact is, if the bonding strength is higher than the internal stresses - problem solved.
Then I tested the strength of bonding layers.
Testing methodology is simple: on the printed cylinder with 2 perimeters I evenly apply pressure with finger on the wall as long as it is not cracked between layers. By the depth pressing I detected the magnitude of the applied strength.
== Print speed affects the adhesion, but not much: I got about the same results for speeds 30-50mm/s;
== Much greater affect temperature of the extrusion: at 220C-260С I got the same bad result (plastic cracked from the slightest finger pressure), but the situation changed dramatically at temperature 270C-280C.
(Also, I have 2 different ABS filaments from different manufacturers, for the second filament I determined the optimal temperature in 260C.)
At this moment I have few succeeded prints (big models up to 150mm in diameter and up to 180mm in height) at 280C without any enclosure and for some models with enabled extrusion cooling fan(!!!):
1) single perimeter, 30mm/s, 0.4 nozzle, 280C, extrusion cooling fan OFF
(top no cracks, it is because of the fact that one of the perimeter for this detail is not enough or need support)
2) 2 perimeters, 70mm/s, 0.4 nozzle, 280C, extrusion cooling fan ON (full speed)
Finally, a few rules for successful work with ABS:
1) maximum heat for your particular filament (note that not all filaments are the same, they have different properties: viscosity, shrinkage, bonding and etc.)
2) the average print speed (I recommend 30-60mm/s)
3) calibrated heated bed and ABS juice for good adhesion of the first layer; ( [www.makerbot.com] )
4) a bit of luck!
UPDATE #1
Most often china thermistors can't show you real temp of your nozzle, when you think its 250C, in real it may only be 220C(or 280C). Don't forget to fine tune your temp sensors.
Edited 6 time(s). Last edit at 11/20/2014 09:58AM by abuharsky.
Re: ABS problems: delamination, cracks, warping [SOLVED]
November 20, 2014 06:10AM
Good info ! i really appreciate your post.Ill try and bumb up the temp with my roll of ABS grinning smiley
November 20, 2014 09:30AM
Ill try this as well since I have an all metal hot end.
I just had a 4.5 hour print crack on me in about 3 places at 230c.
November 25, 2014 07:01AM
One more successful print!
Vase ~150mm x 100mm, 3 perimeters, 280C, 80mm/s, gray low cost ABS.
November 25, 2014 09:18AM
Ive done 2 great prints at 270c with neon green ABS 3mm
December 12, 2014 09:39AM
One more great print
box 100mm X 100mm X 80mm, ABS, 2 perimeters, 15% infill, 0.3 layer, 280C, ZERO delamination
December 12, 2014 10:23PM
Nice work!
_______________________________________
Waitaki 3D Printer
December 15, 2014 08:07PM
I usually take my prints up in temp until they start to look funny from being too hot, then back off 10C. That's where I have found best lamination. But what I am finding now is the quality of the ABS really matters. Some of the cheaper stuff no matter how I print, it just likes to delaminate, or be brittle.
December 15, 2014 09:10PM
I found out that any material -> higher temp == better result smiling smiley
But ABS is so hard to work with, so much warp. Nylon is much much better.
I might get a filastruder and try to make a ABS-Nylon mix to have their good characteristics combined.
I also found out that more walls = better lamination smiling smiley Thicker the better.
December 16, 2014 12:33AM
That's weird because I find the warping with nylon at keast 10 times worse, and that number increases esponentially the larger part you try to create. Which nylon are you using?
BTW I find t-glase the best all around filament to print with. I mostly make functional parts.
December 16, 2014 03:21AM
Yes, I would have thought that Nylon was considerably more difficult to work with. And your right - the quality of the ABS is very significant.
Waitaki 3D Printer
December 17, 2014 04:14PM
I'm using cheapest nylon i could find: Trimmer line! grinning smiley
Sure there is some warping issues with nylon, but they are usually rather small issues.
Nylon requires the extra step of drying it, and damn it picks up moisture fast, but when it's dry it's a dream to work with compared to ABS. Sticks like hell on PVA glue or ABS juice too.
January 23, 2015 09:23AM
one more great print
Edited 2 time(s). Last edit at 01/23/2015 09:25AM by abuharsky.
January 24, 2015 09:46AM
For ABS i have my cooling fan on slow, start with 255-265C, and bed ~100C.
After a layer or too i raise the temp to 285-295, and eventually bed rises to 120C.
PVA glue or ABS juice bottom. I like PVA glue that it's easier to get the parts of at the end, but some models are just so warp prone you need thick ABS juiced one not to warp a corner. Example of such print would be a big rectangle, sharp corners tend to lift
Print speed i use is 100-120mm/s with 25mm/s jerk and 4000mm/s2 acceleration.
January 24, 2015 09:55AM
I believe your thermistor tables are off. @280c most hot ends are going to melt, and most ABS will be over-cooked and brittle.
January 24, 2015 09:14PM
I been also printing a lot with abs and printed 6 of those types of vases, I use to do the crappy abs juice thing now I use that over priced hair spray called 3DLAC its expensive 20 dollars a can but it does along way and since then I have Zero warping and everything sticks really well and once the bed temp lowers to 40 c everything simply lets go with out a fight . and as for those vases I found my 0.8 and my 0.6 nozzles do the best jobs with faster print times then my 0.4
e3d hotend temp 230c
heatbed 100c
print speed@ 55 to 70 mms
I also use cure and after 1mm I bring the flow rate to 98%
No cooling
Edited 1 time(s). Last edit at 01/24/2015 09:15PM by Tibuck.
January 27, 2015 08:23PM
Dirty Steve
All metal hotend ...
January 27, 2015 09:54PM
PulsedMedia
Yup, im running a E3D v5
April 11, 2015 08:58AM
Until recently I had exact the same problems as abuharsky:cracked layers, layers not sticking well.
Previously I used a j-head compatible and it seems all ok. I printed on 235 degrees, but after a while (3 months of printing) the nozzle "came out". After reading this post I suppose the thermistor was probably off and the actual temperature (but I have no way to confirm it) was more like 260 degrees.
So after the 3rd meltdown I threw away the j-head compatible and bought a brand-new E3D v6. All was stable and working well at 235 degrees, except the layers didn't seem to bind well. I printed the Bear Puzzle and even with small layers there were cracks everywhere. I tried different layer thicknesses, slightly different temperatures, different infills, 2 different ABS brands... nothing seemed to help. THEN I came to this page, raised the temperature to 260 degrees, later 265 and the problem was solved! So easy if you think about it... So thanks alot abuharsky!
Bear Puzzle:
printed at probably 235 degrees, 0.2mm layer
[www.thingiverse.com]
Julia Vase:
printed 265 degrees, 0.25mm layer in a spiral. sliced with Slic3r.
Egg Pods:
From left to right:
220, 225, 235, 260 and 265 degrees.
May 18, 2015 11:10AM
I can confirm this is a VERY good solution.
Just printed the best looking print I ever printed so far.
Corners are sharp, external perimeters look good and no delamination what so ever.
Thanks a lot.
May 18, 2015 11:33AM
amplivibs
aFrazatto
Thanks a lot.
I'm happy to read this!
enjoy smiling smiley
Edited 1 time(s). Last edit at 05/18/2015 11:34AM by abuharsky.
May 19, 2015 10:21AM
Wow, glad I stumble on this thread, lots of new ideas to try. Also, I printed off a set of those egg pods too!
May 21, 2015 09:41PM
Hi, I am using mk8 extruder type, I wonder if I'm able to reach up to 270c? Since you guys all using e3d type hotend, is there anyone uses other than e3d type to reach up to 270c?
Just got my cracks last night though and I am running on sangui board so there were no way to control the fan except it is always on, but i do have a fan duct, I took it out last night when printing the back case of my lcd due to cracking occurs when printing it at 240c, .2mm, 3 walls and 4 bottom/top layer
May 21, 2015 10:37PM
Well....to be honest, 250 ° did the trick, i'm running on 260° just for very tin perimeters.
May 25, 2015 12:56PM
250C max for mk8
