ABS delamination from heatbed December 08, 2014 05:44AM |
Re: ABS delamination from heatbed December 08, 2014 06:36AM |
Re: ABS delamination from heatbed December 08, 2014 07:38AM |
| Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: ABS delamination from heatbed December 08, 2014 12:53PM |
I'll try and write about results.Quote
gordonendersby
Have you tried adding a brim around the print
Re: ABS delamination from heatbed December 08, 2014 01:26PM |
Re: ABS delamination from heatbed December 12, 2014 12:18AM |
Re: ABS delamination from heatbed February 28, 2016 05:29AM |
Re: ABS delamination from heatbed February 28, 2016 05:45AM |
Re: ABS delamination from heatbed February 28, 2016 07:32AM |
Re: ABS delamination from heatbed February 28, 2016 03:20PM |
No, it happens time to time, mostly when after I calibrate Z, it autohomes right before start printing and miss just a little bit, which is enough to make first layer's tracks not as wide as they should be. And of course, when it happens I'm restarting the print. As you can see on other photos, it still delaminates when there are no gaps. So, I'm talking about delamination with good solid brim, which I'm unable to tear off easily.Quote
Frans@France
First thing I notice is the space between the lines in the rim. looks like under extruding and would explain that the brim doesn't help as much as it could.
Either I'm missing this step, or doing it in some other way, not knowing how).Quote
Frans@France
Did you measure the average filament width and entered that value in the slicer?
Mostly, because of smell.Quote
Frans@France
Why the PVA/Water mix, why not the ABS/Aceton?
Actually, I think yes.Quote
Frans@France
PS I'm seeing warping and not delamination?
Will shoot on the next print.Quote
Montiey
What does the first layer look like? Can you take a photo?
Re: ABS delamination from heatbed February 29, 2016 12:06AM |
Re: ABS delamination from heatbed February 29, 2016 06:12AM |
You had to enter the filament diameter in the slicer (3.00) but the best thing to do is to measure the filament at a few places for a few meters and then calculate the average width. that average you enter into the slicer. You can also not do that but look at the layers and use the flow setting to increase\decrease extrusion to match your filament width.Quote
stuff
Frans@France
How to measure average filament width and where to put it?
For slicing I'm using Cura 15.04. For good brim overlapping I'm setting initial layer thickness to 0.17 (instead of usual 0.20) and initial layer line width to 155%.
