Layer shift on Y-axis December 15, 2014 01:26AM |
Re: Layer shift on Y-axis December 15, 2014 12:55PM |
Re: Layer shift on Y-axis December 15, 2014 08:11PM |
Re: Layer shift on Y-axis December 16, 2014 09:15AM |
Re: Layer shift on Y-axis December 16, 2014 09:26AM |
Re: Layer shift on Y-axis December 16, 2014 01:08PM |
Dreadnaught426
I've noticed that on my of my prints now, i get shifts in the Y-axis . I have a prusa i3 and. I dont have the nuts on my Z-axis glued to the carriages, the the bit od slack be causing it, or some z-axis wobble of some kind?
Re: Layer shift on Y-axis December 16, 2014 02:52PM |
I'm thinking you should possibly look into adjusting the voltage / current to a motor that is running that hot. The fan is a decent temporary solution, but running the motor that hot can't be good for it in the long run.Quote
roygpa
I solved a pesky Y axis shifting problem by aiming a fan at the Y-Axis (I hit all of them) stepper driver. No matter how I adjusted the driver, it still skipped randomly. After adding a fan to cool it (it was hot enough to burn your finger) it hasn't missed a step.
Re: Layer shift on Y-axis December 16, 2014 03:19PM |
Re: Layer shift on Y-axis December 17, 2014 06:16AM |
Re: Layer shift on Y-axis December 17, 2014 01:59PM |
Re: Layer shift on Y-axis December 17, 2014 02:14PM |
Re: Layer shift on Y-axis December 18, 2014 09:40AM |
Re: Layer shift on Y-axis December 18, 2014 11:10AM |
Re: Layer shift on Y-axis December 18, 2014 04:24PM |
Re: Layer shift on Y-axis December 19, 2014 09:45PM |
