Layer shift on Y-axis
December 15, 2014 01:26AM
I've noticed that on my of my prints now, i get shifts in the Y-axis . I have a prusa i3 and. I dont have the nuts on my Z-axis glued to the carriages, the the bit od slack be causing it, or some z-axis wobble of some kind?
open | download - tmp_25886-20141215_010835698653611.jpg (109.3 KB)
Re: Layer shift on Y-axis
December 15, 2014 12:55PM
Looks like simple skipped steps to me. Look for friction in the Y axis, or possibly turn down speed or acceleration settings.
December 15, 2014 08:11PM
Should I turn down the speed by adjusting the pot on the board or just do it in slicer?
December 16, 2014 09:15AM
Dear All
I've got the same problem, but much worse. I'm a new user of a printer and here in the forum. The offset is not the same, but up to 5mm per layer. A test cube of 10x10x10mm has got 10mm offset on the last layer. Does somebody have got an idea?
Thank you in advance for the answers.
kind regards Dirk
open | download - Y.JPG (59.6 KB)
December 16, 2014 09:26AM
I solved a pesky Y axis shifting problem by aiming a fan at the Y-Axis (I hit all of them) stepper driver. No matter how I adjusted the driver, it still skipped randomly. After adding a fan to cool it (it was hot enough to burn your finger) it hasn't missed a step.
December 16, 2014 01:08PM
Dreadnaught426
Hi Dreadnaught,
I have this exact problem also and have been trying to solve the issue for weeks.
I have tried everything:
Stiffened my reprap so its now very rigid.
I have tried different slicers(Cura, Slic3r, Mattercontrol and Kisslicer)
Different belt tightness.
Endless firmware changes(Marlin)
The thing I'm looking at now is that maybe its either the Ramps1.4 board or stepper driver causing it. When I'm printing my prints are spot on but then all of a sudden I get the same issue(not always in the same place on the print) you are having and its not the stepper loosing steps. Its seems there may be some type of interference in the electronics or something similar.
Regards
Kevin
December 16, 2014 02:52PM
roygpa
I'm thinking you should possibly look into adjusting the voltage / current to a motor that is running that hot. The fan is a decent temporary solution, but running the motor that hot can't be good for it in the long run.
There is a thread around here that goes into details of how to adjust stepper motor voltages to find their "sweet spot" and that may be what the OP needs as well.
December 16, 2014 03:19PM
Hi Dreadnaught426 ;
in my opinion: this is a really common problem in 3D printer community.
Please check this out:
1. what is your stepper motor driver's voltage? please measure each axis voltages.if you don't know how to measure, please google it or ask to someone to know.
2. What is your speeds? Sometimes high this problem occurs ( missing steps ) at high speeds.
3. please check your limit switch connections. maybe there is a loose contact in cable.
4. check your limit switch settings in firmware. especially ( true/false settings)
hopefully this advices help you to solve the problem smiling smiley
Custom 3D Printer,
Mechanical Engineer
December 17, 2014 06:16AM
In my case its not the steppers loosing steps it seems as though the stepper moves but does return to the same start place(its very slightly off). Have tried turning the pots to give more torque/current
It has nothing to do with speed I have tried slow printing and fast and still the same.
As for limit switch connections how can this possibly give the errors both me and dreadnaught are having !
December 17, 2014 01:59PM
I tried a slower print, 50% speed. It seemed to help. I uped another print to 75% of normal speed and had problems. I had a belt tensioner on and took it off and uped the voltage on the pot, just tuned it to the sound. I will put a meter on it after this print is done so that their not over/under powered. I'm useing the default speeds in slic3r. As far as interference, what can cause it? I have a panelolu2 controling it, a usb hub powering some fans for the PSU and the Melzi, i do have all of the nema wires bundled up together (I don't want to cut anything as it will be going in a box and everything will be moved around), could that be causeing it? What can i use to shield them?
Edited 1 time(s). Last edit at 12/17/2014 08:15PM by Dreadnaught426.
December 17, 2014 02:14PM
Green 50%, Black 75% of normal speed and the skinny black is at 100%.
open | download - tmp_31299-20141217_1359321493772510.jpg (102 KB)
open | download - tmp_31299-20141217_140023-1718438023.jpg (120.9 KB)
open | download - tmp_31299-20141217_140009-1455927128.jpg (122.7 KB)
December 18, 2014 09:40AM
Did a couple of prints at 100% with everything calibrated. Still not very nice. Printed something at 50% and it turned out great. I guess slow and steady wins the race this time.
December 18, 2014 11:10AM
How fast are you printing in mm/sec?
50% and such dont mean anything without the actual 100% speed in mm/sec. You might just be going too fast.
Most of my prints are at 40mm/sec to 90mm/sec depending on the size and shape of the parts.
December 18, 2014 04:24PM
Sli3r default is 30 mm/sec. So most of it is at 15 i guess.
December 19, 2014 09:45PM
Looking at the beginning of this post -
I thought I would try posting on this thread instead of reposting a new question with the same info.
I have the same style Reprap machine - Prusa I3 Rework
and similar cheap-o chinese Ramps board and stepper drivers.
Machine has been running great for about 6 months and then it started stepping on the Y axis badly.
Not sure what that heck has happened. Changed the stepper driver and repeats the same problem.
The motor seems to run nice and cool or slightly warm.
I have a fan cooling the Ramps board and stepper drivers.
I have fried the Arduino - Mega 2650 - voltage regulator a couple times by accident before, but replaced them easily.
I'm wondering about 2 possibilities here but could use some fellow repapper's thoughts:
1 - Could it be a failing Ramps board? and if so, what part of the board is the culprit here?
2 - (Similar) Could the Arduino be a failing?
3 - Or - could it be Cura? Up till recently, it has performed wonderfully.
Addendum: As i write this - I decided to give one last idea a try. Try the default print settings - Fast, low quality print.
Sofar, 1/3 into the progress ......strangely, with no 'on-the-fly' speed adjustments - it seems to be great.
But the overall print speed is very fast. Like 60 - or 70 mm/sec fast (just a guess).
But no skips.
Any thoughts gents or ladies?
Thanks - JD
Software is Cura (latest version) using expert settings.
Heartbox model seems to be ok - from Thingiverse.
overall print speed: 30mm/sec
temp: 190c
layer height: .2 mm
Edited 1 time(s). Last edit at 12/19/2014 09:48PM by jdmech.
Prusa I3 - Rework (home built)
w/ heated print bed. Borosilicate glass plate.
Ramps 1.4 board, Arduino 2650
Thermaltake 750watt power supply
Ulti-panel lcd controller
Marlin firmware
Cura - slicer/print software
open | download - Heart box fail-2.JPG (138.4 KB)
open | download - Heart box fail.JPG (34.9 KB)
