slower speed on my 3d printer.
Posted by RDEng
December 15, 2014 11:58AM
Hello Everyone!!
I was set the perimeters and travel speed 120mm/s on slic3r. Travel seems like the real 120mm/s but perimeter speed actually slower than. why printer doing that?
Any advice?
Thanks
Custom 3D Printer,
Mechanical Engineer
Re: slower speed on my 3d printer.
December 15, 2014 12:53PM
Do you have other limits in firmware? Also sometimes there is a perimeter multiplier that tells the slicer to go slower on perimeters. This is due to the belief that slower printing is higher quality and outside perimeters are the public face of your print. Other things that slow down a print are speed and acceleration settings for the movement axes and don't forget the extruder. You might be running into firmware limits for extrusion rate.
December 16, 2014 07:50AM
i think problem source is Gcode. Slic3r . program using F600 for perimeter , i changed the F600 to F3600 and printer goes faster. But why slic3r using F600 no matter what you speed value?
Custom 3D Printer,
Mechanical Engineer
December 16, 2014 07:52AM
There are a few options for that.
Perimeter Speed
Outer Perimeter Speed
cooling: slow down
