Printig above heatbed December 27, 2014 04:25PM |
Re: Printig above heatbed December 27, 2014 05:43PM |
Re: Printig above heatbed December 28, 2014 03:40PM |
Re: Printig above heatbed December 29, 2014 10:32PM |
Stalker
Hi guys, yesterday I've tried couple of prints on my printer and found out that the printing always starts about 1.25 cm above the glass on the heated bed. The home position for z axis is set to be approximately 0.2mm (1 sheet of paper) above the glass however as the printing starts the z axis homes and then moves 1.25 cm above the right hand corner of the heat bed and starts to print. Obviously the filament doesn't stick and just blobs on the nozzle. I can't set the homing position any lower as the nozzle would be scraping the glass already and wouldn't be able to home. Any ideas how to fix it ? I am using ramps 1.4 with marlin firmware and for the actual printing I am using slicer to generate the g code and pronterface for the actual print. I've tried three different stl files to eliminate the possibility of a bad command in the gcode. Any advice would be appreciated.
Re: Printig above heatbed December 30, 2014 12:10AM |
