slicer issue: thiner diameter
January 08, 2015 01:49PM
Hi! I've created a small rod with a hole in the one half of the rod and after its slicing I've find out that the half of the rod has smaller diameter than it should have!
Look at the attachment please. I use Slic3r 1.1.7, 0.2 layer height. I think it's not correct output of the slicer, or?
Model of the tube:
$fn = 50;
e = 0.1;
h1 = 10;
h1_full = 5;
h2 = 6;
h1_diameter_in = 3.4;
h1_diameter_out = 5;
h2_diameter_out = 2.6;
difference() {
cylinder(h1, h1_diameter_out/2, h1_diameter_out/2);
#translate([0,0,-h1_full-e]) cylinder(h1+2*e, h1_diameter_in/2, h1_diameter_in/2);
translate([0,0,h1]) cylinder(h2, h2_diameter_out/2, h2_diameter_out/2);
open | download - slicer_issue.jpg (170.4 KB)
Re: slicer issue: thiner diameter
January 09, 2015 03:09AM
What is your nozzle-size? What is your setting in slic3r as default extrusion width?
January 09, 2015 02:18PM
here are the params:
  • nozzle-size: 0.4 mm
  • default extrusion width: 0.5 mm
January 09, 2015 06:43PM
Ok, I expected that.
Change your extrusion width to 0.4. Then it should be better.
Your default extrusion width don't fit (5 - 3.4) / 2 = 0,8mm.
2x 0.5mm > 0.8mm
1x 0.5mm < 0.8mm
2x 0.4mm = 0.8mm smileys with beer
January 12, 2015 06:55PM
That makes sense.
Thanks Wurstnase!
