Printing issues with sides of print looks stringy or melting January 11, 2015 06:17PM |
Re: Printing issues with sides of print looks stringy or melting January 11, 2015 09:10PM |
Re: Printing issues with sides of print looks stringy or melting January 11, 2015 10:04PM |
Re: Printing issues with sides of print looks stringy or melting January 12, 2015 12:10AM |
tmorris9
You skipped a lot of pertinent info like temperature(s), material, speed....
But it looks like ABS and I am going to guess that your heated bed is too hot for starters (no hotter than 90c but 85c is better) also you probably don't have retraction turned on (set to 2mm to start) and have you calibrated your extruder? I.E. extruding 100mm uses exactly 100mm? Have you measured your filament using calipers then put that measurement into the slicer? This should be done with every new roll. Don't just put in 3mm as that is almost never the actual measurement and this can make a big difference in the amount output.
