I have a show stopper problem on the Z axis of a Prusa i3 with NEMA-17 motors (wired in series, not parallel).
I can run the Z axis up and down all day manually through Pronterface and never loose sync between the two Z axis motors. However about 3 seconds into a test printing run (after the bed and extruder reaches working temp), the Z axis rises slightly from the home position, shakes rapidly making a burrrting noise, then goes to the middle of the bed to start printing. During this odd initial raised 'burrtt' near the home position the left and right motors loose rotational sync by around half to one and half turns. This destroys the X levelling...
Anybody know why the print run does some violent Z moves initially like this, when there seems to be no issues during manual movements ?
I've tried increasing the Z motor current limit pot to 0.8V, but the stepper driver gets hot (like near 100C) in a minute or two, so I backed the pot off again to 0.6V.
Martin
