cura retractation doesn't retract where it should.
Posted by victorjung
January 17, 2015 04:31AM
Hi guys.I tried to set retractation on cura for my printer. I think the settings are OK now except it doesn't retract every where. Only for very small distance. The problem is that the leaking filament on long distance ~50mm cause a lack of plastic where you need to have it after the leak... I am even wondering if it retracts only for distance below the settings instead of retract for bigger distance...
Any idea ?
Edited 1 time(s). Last edit at 01/17/2015 04:39AM by victorjung.
Re: cura retractation doesn't retract where it should.
January 17, 2015 10:02AM
I have the same issues with Cura. Id love for it to retract when it moves but it wont. instead it leaves a streak of plastic and then I end up short when it starts printing again.
January 17, 2015 10:44AM
I, unchecked combing in expert mode setting, and now it retracts also inside the print. Of course you have to allow retraction in first place.
January 18, 2015 12:04PM
Might have to try that...
