How To Print With InnoFlex ?
Posted by Plasteroid
January 19, 2015 12:44PM
I have tried with 250C and 10mm/s speed. After the first layer the filament stops melting and going throught the hot end. I think that this needs very exact settings. What about the fan? I have a direct drive extruder.
Properties Innofil3D InnoFlex Filament 2.85mm
Filament : Innofil3D InnoFlex PLA
Chemical name: DSM Arnitel Eco
Flexible 3D Printing Filament
High UV resistance
Destiny: 1150kg/m3
Diameter 2.85mm: 2.85 +/- 0.10mm
Max. roundness deviation 2.85mm: +/- 0,10mmmm
Delivered on a practical coil á 500g
Melting point: 180°C
Glass transition temperature Tg: -35 °C
Optimum extrusion temperature : 210-250 °C (depending on the printer and print accuracy)
Print speed guidelines: 30-80 mm/s
No unpleasant odor during printing
Includes all common 3D printers compatible on the market! (2.85mm)
Diameter of the coil holder : 4.90 cm
Prusa i3, Ramps 1.4. Catnozzle 0.4mm
SketchUp - Enveloping Globoid Worm Gear - Part One - 3D Printed: [youtu.be]
DesignSpark Mechanical & more precise screw thread: [youtu.be]
Nicer Screw Thread In SketchUp ( Bolts,Nuts): [youtu.be]
How To Model A Heart Shape In SketchUp: [youtu.be]
How To Draw 3D Printable Snap Fit Ball Joint In SketchUp: [youtu.be]
