Reverse printed object?
Posted by GRAYWOLF
January 22, 2015 03:21PM
I've opened an object in cura and exported it to g-code but its been printed out mirrored.
I've also entered this model in cura but yet its also off centre.
Can someone tell me where to look for the gremlins inhabiting my printer?
Re: Reverse printed object?
January 22, 2015 04:23PM
I guess one of your axis (y-axis?)is going the wrong way.
What printer do you have?
Edit: also mirrored prints [forums.reprap.org]
Edited 1 time(s). Last edit at 01/22/2015 04:28PM by gforce1.
January 23, 2015 01:29AM
its also a Prusa i3 but it has only happened on this one object!
Also In cura the object is place in the centre of the bed from left to right but when printed it faces (off centre!) Xaxis rear! rotated 90 degrees !
Edited 1 time(s). Last edit at 01/23/2015 01:29AM by GRAYWOLF.
January 23, 2015 01:15PM
gforce1
X and Y were swapped !
Thanks bud.
Try again.
January 23, 2015 02:38PM
GRAYWOLF
Thanks bud.
Try again.
Huh? If X and Y are swapped, the object will not be mirrored - it will just be rotated 180 degrees.
If your objects are truly mirrored, then X OR Y is mirrored - not both
January 24, 2015 03:36AM
Is there something in the G-code that could cause this?
January 24, 2015 08:52AM
GRAYWOLF
No.
I think you have a problem with the direction off your axis. Or at least one off them
When you press + 50 mm for x-axis is the carriage moving to the right?
When you press + 50 mm for y-axis is the heatbed moving towards you ?
January 24, 2015 08:55AM
It does now, I switched the axis and flipped the connections but now the extruder is playing up (didn't touch the wiring on it)
